ThickenLayeredCells_server_manager_modules_data.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv5.13
4 //
5 #ifndef ThickenLayeredCells_server_manager_modules_data_h
6 #define ThickenLayeredCells_server_manager_modules_data_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/ThickenLayeredCells/Filters/ThickenLayeredCells.xml
15 "<ServerManagerConfiguration>\n"
16 " <ProxyGroup name=\"filters\">\n"
17 " <SourceProxy name=\"ThickenCells\" class=\"vtkThickenLayeredCells\" label=\"Thicken Layered Cells\">\n"
18 " <Documentation>\n"
19 " Filter to thicken cells in layers using average thickeness along edges between layers.\n"
20 " </Documentation>\n"
21 " <InputProperty\n"
22 " name=\"Input\"\n"
23 " command=\"SetInputConnection\">\n"
24 " <ProxyGroupDomain name=\"groups\">\n"
25 " <Group name=\"sources\"/>\n"
26 " <Group name=\"filters\"/>\n"
27 " </ProxyGroupDomain>\n"
28 " <DataTypeDomain name=\"input_type\">\n"
29 " <DataType value=\"vtkDataSet\"/>\n"
30 " </DataTypeDomain>\n"
31 " <InputArrayDomain attribute_type=\"cell\"\n"
32 " name=\"input_array\"\n"
33 " number_of_components=\"1\" />\n"
34 " </InputProperty>\n"
35 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
36 " element_types=\"0 0 0 0 2\"\n"
37 " name=\"SelectThickness\"\n"
38 " label=\"Thickness\"\n"
39 " number_of_elements=\"5\"\n"
40 " default_values=\"0\">\n"
41 " <ArrayListDomain attribute_type=\"Scalars\" name=\"array_list\">\n"
42 " <RequiredProperties>\n"
43 " <Property function=\"Input\" name=\"Input\" />\n"
44 " </RequiredProperties>\n"
45 " </ArrayListDomain>\n"
46 " <Documentation>Select the 'thickness' array.</Documentation>\n"
47 " </StringVectorProperty>\n"
48 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
49 " element_types=\"0 0 0 0 2\"\n"
50 " name=\"SelectLayer\"\n"
51 " label=\"Layer\"\n"
52 " number_of_elements=\"5\"\n"
53 " default_values=\"1\">\n"
54 " <ArrayListDomain attribute_type=\"Scalars\" name=\"array_list\">\n"
55 " <RequiredProperties>\n"
56 " <Property function=\"Input\" name=\"Input\" />\n"
57 " </RequiredProperties>\n"
58 " </ArrayListDomain>\n"
59 " <Documentation>Select the 'layer' array.</Documentation>\n"
60 " </StringVectorProperty>\n"
61 " <IntVectorProperty name=\"EnableThickening\"\n"
62 " command=\"SetEnableThickening\"\n"
63 " number_of_elements=\"1\"\n"
64 " default_values=\"1\">\n"
65 " <Documentation>\n"
66 " Enable/disable thickening. When disabled, the filter simply acts as a\n"
67 " pass-through.\n"
68 " </Documentation>\n"
69 " <BooleanDomain name=\"bool\" />\n"
70 " </IntVectorProperty>\n"
71 " </SourceProxy>\n"
72 " </ProxyGroup>\n"
73 "</ServerManagerConfiguration>\n"
74 "\n";
75 // Get single string
77 {
78
80  size_t len = ( 0
81  + len0 );
82  char* res = new char[ len + 1];
83  size_t offset = 0;
85  assert(offset == len);
86  res[offset] = 0;
87  return res;
88 }
89
90
91
92 #endif
offset
static const char *const ThickenLayeredCells_server_manager_modulesThickenLayeredCellsInterface0
char * ThickenLayeredCells_server_manager_modulesThickenLayeredCellsGetInterfaces()
