1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsAMR-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsAMR-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsAMR-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRConnectivity.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRDualClip.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRDualContour.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRDualGridHelper.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRFragmentIntegration.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkAMRFragmentsFilter.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkPVAMRDualClip.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkPVAMRDualContour.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/vtkPVAMRFragmentIntegration.h"
100  )
101 endif()
102
103 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
104  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/AMR/vtkPVVTKExtensionsAMRModule.h")
105 endif()
106
107 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
108  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsAMR" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/LICENSE")
109 endif()
110
111 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
112  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/AMR/vtkPVVTKExtensionsAMR.spdx")
113 endif()
114
Generates fragment analysis from an amr volume and a previously run contour on that volume...
Clip (with scalars) an AMR volume to unstructured grid.
A meta filter that combines vtkAMRConnectivity, vtkAMRFragmentIntegration, vtkAMRDualContour, vtkExtractCTHPart to allow all the fragment analysis in one easy UI.
Extract particles and analyse them.
Generates contour given one or more cell array and a volume fraction value.
Tools for processing AMR as a dual grid.
Identify fragments in the grid.
Generates a contour surface given one or more cell arrays and a volume fraction value.
