Tools for processing AMR as a dual grid. More...
#include <vtkAMRDualGridHelper.h>
| int | Initialize (vtkNonOverlappingAMR *input) |
| int | SetupData (vtkNonOverlappingAMR *input, const char *arrayName) |
| const double * | GetGlobalOrigin () |
| const double * | GetRootSpacing () |
| int | GetNumberOfBlocks () |
| int | GetNumberOfLevels () |
| int | GetNumberOfBlocksInLevel (int level) |
| vtkAMRDualGridHelperBlock * | GetBlock (int level, int blockIdx) |
| vtkAMRDualGridHelperBlock * | GetBlock (int level, int xGrid, int yGrid, int zGrid) |
| void | CopyDegenerateRegionBlockToBlock (int regionX, int regionY, int regionZ, vtkAMRDualGridHelperBlock *lowResBlock, vtkDataArray *lowResArray, vtkAMRDualGridHelperBlock *highResBlock, vtkDataArray *highResArray) |
| I am generalizing the code that copies lowres blocks to highres ghost regions. More... | |
| void | QueueRegionRemoteCopy (int regionX, int regionY, int regionZ, vtkAMRDualGridHelperBlock *lowResBlock, vtkDataArray *lowResArray, vtkAMRDualGridHelperBlock *highResBlock, vtkDataArray *highResArray) |
| This queues up either a copy from a remote process to this process or a copy from this process to a remote process. More... | |
| void | ProcessRegionRemoteCopyQueue (bool hackLevelFlag) |
| This should be called on every process. More... | |
| void | ClearRegionRemoteCopyQueue () |
| Call this before adding regions to the queue. More... | |
| virtual int | GetSkipGhostCopy () |
| An option to turn off copying ghost values across process boundaries. More... | |
| virtual void | SetSkipGhostCopy (int) |
| virtual void | SkipGhostCopyOn () |
| virtual void | SkipGhostCopyOff () |
| virtual int | GetEnableDegenerateCells () |
| Turn on/off the ability to create meshing between levels in the grid. More... | |
| virtual void | SetEnableDegenerateCells (int) |
| virtual void | EnableDegenerateCellsOn () |
| virtual void | EnableDegenerateCellsOff () |
| virtual int | GetEnableAsynchronousCommunication () |
| When this option is on (the default) and a controller that supports asynchronous communication (like MPI) is detected, use asynchronous communication where appropriate. More... | |
| virtual void | SetEnableAsynchronousCommunication (int) |
| virtual void | EnableAsynchronousCommunicationOn () |
| virtual void | EnableAsynchronousCommunicationOff () |
| virtual vtkMultiProcessController * | GetController () |
| The controller to use for communication. More... | |
| virtual void | SetController (vtkMultiProcessController *) |
| virtual char * | GetArrayName () |
| It is convenient to get this here. More... | |
| static vtkAMRDualGridHelper * | New () |
| static vtkAMRDualGridHelper * | SafeDownCast (vtkObject *o) |
This helper object was developed to help the AMR dual grid connectivity and integration filter but I also want a dual grid iso surface filter so I mad it a separate class. The API needs to be improved to make it more generally useful. This class will take advantage of some meta information, if available from a coprocessing adaptor. If not available, it will compute the information.
Definition at line 39 of file vtkAMRDualGridHelper.h.
Definition at line 43 of file vtkAMRDualGridHelper.h.
If the ghost values are already correct, then the extra communication is not necessary. If this assumption is wrong, this option will produce cracks / seams. This is off by default.
This is on by default. Set this before you call initialize.
This can prevent processes from blocking while waiting for communication in other processes to finish.
| int vtkAMRDualGridHelper::Initialize | ( | vtkNonOverlappingAMR * | input | ) |
| int vtkAMRDualGridHelper::SetupData | ( | vtkNonOverlappingAMR * | input, |
| const char * | arrayName | ||
Definition at line 90 of file vtkAMRDualGridHelper.h.
Definition at line 91 of file vtkAMRDualGridHelper.h.
Definition at line 92 of file vtkAMRDualGridHelper.h.
Definition at line 93 of file vtkAMRDualGridHelper.h.
| vtkAMRDualGridHelperBlock* vtkAMRDualGridHelper::GetBlock | ( | int | level, |
| int | blockIdx | ||
| int | xGrid, | ||
| int | yGrid, | ||
| int | zGrid | ||
| void vtkAMRDualGridHelper::CopyDegenerateRegionBlockToBlock | ( | int | regionX, |
| int | regionY, | ||
| int | regionZ, | ||
| vtkAMRDualGridHelperBlock * | lowResBlock, | ||
| vtkDataArray * | lowResArray, | ||
| vtkAMRDualGridHelperBlock * | highResBlock, | ||
| vtkDataArray * | highResArray | ||
I need to do this for the clip filter (level mask).
For transitions between levels, degeneracy works well to create and contour wedges and pyramids, but the volume fraction values in the high-level blocks ghost cells need to be the same as the closest cell in the low resolution block. These methods copy low values to high.
| void vtkAMRDualGridHelper::QueueRegionRemoteCopy | ( | int | regionX, |
| int | regionY, | ||
| int | regionZ, | ||
Only the local block needs an array. LowRes block is the source.
| void vtkAMRDualGridHelper::ProcessRegionRemoteCopyQueue | ( | bool | hackLevelFlag | ) |
It processes the queue of region copies. It sends and copies the regions into blocks.
| void vtkAMRDualGridHelper::ClearRegionRemoteCopyQueue | ( | ) |
It clears the queue.
1.8.13 on Sat Dec 13 2025
