1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsIOCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsIOCore-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkAdditionalFieldReader.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkCSVWriter.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkFileSeriesReader.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkFileSeriesWriter.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkMetaReader.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkParallelSerialWriter.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkPVDReader.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkStringReader.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkStringWriter.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkXMLCollectionReader.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkXMLPVDWriter.h"
102  )
103 endif()
104
105 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCore/vtkPVVTKExtensionsIOCoreModule.h")
107 endif()
108
109 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsIOCore" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/LICENSE")
111 endif()
112
113 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCore/vtkPVVTKExtensionsIOCore.spdx")
115 endif()
116
Given a string, write it to a file.
ParaView-specific vtkXMLCollectionReader subclass.
Definition: vtkPVDReader.h:17
Read a file wrapping many other XML files.
meta-reader to read file series
meta-writer for writing a file series using writers that are not time-aware.
Read a file and return a string.
read field data arrays and add to an input
parallel meta-writer for serial formats
Common functionality for meta-readers.
Definition: vtkMetaReader.h:21
CSV writer for vtkTable/vtkDataSet/vtkCompositeDataSet Writes a vtkTable/vtkDataSet/vtkCompositeDataS...
Definition: vtkCSVWriter.h:23
Data writer for ParaView.
