vtkStringReader Class Reference
Read a file and return a string. More...
#include <vtkStringReader.h>
Inheritance diagram for vtkStringReader:
Collaboration diagram for vtkStringReader:
enum  DesiredOutputPrecision
 vtkGetCharFromStdStringMacro (String)
 Get the read string. More...
 vtkSetStdStringFromCharMacro (FileName)
 Specify the file name to read from. More...
 vtkGetCharFromStdStringMacro (FileName)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkStringReaderNew ()
static vtkStringReaderSafeDownCast (vtkObject *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkStringReader ()
 ~vtkStringReader () override
vtkTypeBool ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double Progress
char * ProgressText
unsigned long ErrorCode
Definition at line 14 of file vtkStringReader.h.
Definition at line 18 of file vtkStringReader.h.
◆ vtkStringReader()
vtkStringReader::vtkStringReader ( )
◆ ~vtkStringReader()
vtkStringReader::~vtkStringReader ( )
static vtkStringReader* vtkStringReader::New ( )
virtual const char* vtkStringReader::GetClassName ( )
static int vtkStringReader::IsTypeOf ( const char *  type)
virtual int vtkStringReader::IsA ( const char *  type)
static vtkStringReader* vtkStringReader::SafeDownCast ( vtkObject o)
void vtkStringReader::PrintSelf ( ostream &  os,
◆ vtkGetCharFromStdStringMacro() [1/2]
vtkStringReader::vtkGetCharFromStdStringMacro ( String  )
◆ vtkSetStdStringFromCharMacro()
vtkStringReader::vtkSetStdStringFromCharMacro ( FileName  )
◆ vtkGetCharFromStdStringMacro() [2/2]
vtkStringReader::vtkGetCharFromStdStringMacro ( FileName  )
◆ FillInputPortInformation()
int vtkStringReader::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ FillOutputPortInformation()
int vtkStringReader::FillOutputPortInformation ( int  port,
vtkInformation info
◆ ProcessRequest()
vtkTypeBool vtkStringReader::ProcessRequest ( vtkInformation request,
vtkInformationVector outputVector
◆ RequestData()
virtual int vtkStringReader::RequestData ( vtkInformation ,
vtkInformationVector **  ,
protectedvirtual
