1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/vtkExodusFileSeriesReader.h" 48 "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOExodus/vtkPVVTKExtensionsIOExodusModule.h" 52 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 53 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVVTKExtensionsIOExodus-hierarchy.txt
vtk/hierarchy/ParaView/vtkPVVTKExtensionsIOExodus-hierarchy.txt
") 56 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 58 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.5.13
" 59 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.1
" 61 if(EXISTS "${file}
" AND 62 NOT IS_SYMLINK "${file}
") 65 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 68 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 69 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.5.13
" 70 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.1
" 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.5.13
" 74 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so.1
" 76 if(EXISTS "${file}
" AND 77 NOT IS_SYMLINK "${file}
") 80 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 81 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 82 if(CMAKE_INSTALL_DO_STRIP) 83 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 89 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 90 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
" AND 91 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
") 93 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
" 94 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 96 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
") 97 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
" AND 98 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
") 100 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
" 101 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 102 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 103 if(CMAKE_INSTALL_DO_STRIP) 104 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOExodus-pv5.13.so
") 109 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsIOExodus
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/LICENSE
