int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| All pipeline passes are forwarded to the internal reader. More...
virtual int | CanReadFile (const char *filename) |
| CanReadFile is forwarded to the internal reader if it supports it. More...
virtual void | AddFileName (const char *fname) |
| Adds names of files to be read. More...
virtual void | RemoveAllFileNames () |
| Remove all file names. More...
virtual unsigned int | GetNumberOfFileNames () |
| Returns the number of file names added by AddFileName. More...
virtual const char * | GetFileName (unsigned int idx) |
| Returns the name of a file with index idx. More...
const char * | GetCurrentFileName () |
unsigned long | GetErrorCode () override |
| Return the error code of the reader. More...
virtual int | GetUseMetaFile () |
| If true, then use the meta file. More...
virtual void | SetUseMetaFile (int) |
virtual void | UseMetaFileOn () |
virtual void | UseMetaFileOff () |
virtual bool | GetIgnoreReaderTime () |
| If true, then treat file series like it does not contain any time step values. More...
virtual void | SetIgnoreReaderTime (bool) |
virtual void | IgnoreReaderTimeOn () |
virtual void | IgnoreReaderTimeOff () |
| vtkMetaReader () |
| ~vtkMetaReader () override |
vtkMTimeType | GetMTime () override |
| Return the MTime when also considering the internal reader. More...
virtual void | SetReader (vtkAlgorithm *) |
| Set/get the internal reader. More...
virtual vtkAlgorithm * | GetReader () |
void | SetMetaFileName (const char *name) |
| Get/set the filename for the meta-file. More...
char * | GetMetaFileName () |
virtual vtkIdType * | GetFileIndexRange () |
| Returns the available range of file indexes. More...
virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
virtual void | GetFileIndexRange (vtkIdType [2]) |
vtkIdType | GetFileIndex () |
| Get/set the index of the file to read. More...
void | SetFileIndex (vtkIdType i) |
virtual void | SetFileNameMethod (const char *) |
| Name of the method used to set the file name of the internal reader. More...
virtual char * | GetFileNameMethod () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkExodusFileSeriesReader () |
| ~vtkExodusFileSeriesReader () override |
int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestInformationForInput (int index, vtkInformation *request, vtkInformationVector *outputVector) override |
| Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
virtual void | FindRestartedResults () |
| vtkFileSeriesReader () |
| ~vtkFileSeriesReader () override |
int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
virtual int | RequestUpdateTimeDependentInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | FillOutputPortInformation (int port, vtkInformation *info) override |
virtual int | ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX) |
| Reads a metadata file and returns a list of filenames (in filesToRead). More...
virtual void | UpdateMetaData () |
| Re-reads information from the metadata file, if necessary. More...
void | ResetTimeRanges () |
| Resets information about TimeRanges. More...
void | RemoveAllFileNamesInternal () |
| Add/Remove filenames without changing the MTime. More...
void | AddFileNameInternal (const char *) |
virtual void | RemoveAllRealFileNamesInternal () |
| Remove all real file names. More...
void | CopyRealFileNamesFromFileNames () |
| Set the real filenames to those in the internal FileNames. More...
int | ChooseInput (vtkInformation *) |
virtual void | Set_MetaFileName (const char *) |
virtual char * | Get_MetaFileName () |
virtual void | Set_FileIndex (vtkIdType) |
virtual vtkIdType | Get_FileIndex () |
void | ReaderSetFileName (const char *filename) |
int | ReaderCanReadFile (const char *filename) |
std::string | FromRelativeToMetaFile (const char *metaFileName, const char *fileName) |
| 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataObjectAlgorithm () |
| ~vtkDataObjectAlgorithm () |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
meta-reader to read Exodus file series from simulation restarts
Add some special sauce to the superclass that allows it to work with the parallel Exodus reader. Specifically, changing the file name causes the selected output arrays to be cleared out. This class saves and restores the information.
Definition at line 24 of file vtkExodusFileSeriesReader.h.
