1 #define _paraview_add_plugin_built_shared 1 2 #define _paraview_add_plugin_with_initializers 0 3 #define _paraview_add_plugin_with_python 0 4 #define _paraview_add_plugin_with_ui 0 5 #define _paraview_add_plugin_with_xml 1 7 #define PARAVIEW_BUILDING_PLUGIN 8 #define PARAVIEW_PLUGIN_BUILT_SHARED _paraview_add_plugin_built_shared 11 #if _paraview_add_plugin_with_ui 17 #if _paraview_add_plugin_with_xml 21 #if _paraview_add_plugin_with_python 25 #if _paraview_add_plugin_with_initializers 30 #if _paraview_add_plugin_with_ui 37 #if _paraview_add_plugin_with_initializers 40 #if _paraview_add_plugin_with_xml 43 #if _paraview_add_plugin_with_python 48 #if _paraview_add_plugin_with_ui 51 Q_PLUGIN_METADATA(IID
"com.kitware/paraview/VTKmFiltersPlugin")
60 {
return "VTKmFilters"; }
90 {
return "VTKm many-core filters"; }
104 #if _paraview_add_plugin_with_xml 108 void GetXMLs(std::vector<std::string> &xmls)
override;
119 #if _paraview_add_plugin_with_ui 123 QObjectList interfaces()
override;
126 #if _paraview_add_plugin_with_python 127 void GetPythonSourceList(std::vector<std::string>& modules,
128 std::vector<std::string>& sources,
129 std::vector<int>& package_flags)
override;
132 #if _paraview_add_plugin_with_initializers 133 void Initialize()
override;
vtkClientServerInterpreterInitializer::InterpreterInitializationCallback GetInitializeInterpreterCallback() override
Returns the callback function to call to initialize the interpretor for the new vtk/server-manager cl...
void GetXMLs(std::vector< std::string > &xmls) override
bool GetRequiredOnServer() override
bool GetRequiredOnClient() override
