#include "vtk_cgns_mangle.h"#include <stdint.h>#include <inttypes.h>
| #define | CG_BUILD_HDF5 1 |
| #define | CG_BUILD_LEGACY 0 |
| #define | CG_BUILD_64BIT 1 |
| #define | CG_BUILD_SCOPE 1 |
| #define | CG_BUILD_BASESCOPE 0 |
| #define | CG_BUILD_PARALLEL 0 |
| #define | CG_BUILD_COMPLEX_C99_EXT 0 |
| #define | CG_MAX_INT32 0x7FFFFFFF |
| #define | CG_LONG_T int64_t |
| #define | CG_U_LONG_T uint64_t |
| #define | to_ADF_ID(ID, ADF_ID) memcpy(&(ADF_ID),&(ID),sizeof(hid_t)) |
| #define | to_HDF_ID(ADF_ID, ID) memcpy(&(ID),&(ADF_ID),sizeof(hid_t)) |
| #define | HDF5_HAVE_MULTI_DATASETS 0 |
| #define | HDF5_HAVE_COLL_METADATA 0 |
| #define | HDF5_HAVE_FILE_SPACE_STRATEGY 0 |
| #define | CG_HAVE_STAT64_STRUCT 0 |
| #define | CG_SIZEOF_SIZE 64 |
| #define | CG_SIZE_DATATYPE "I8" |
| #define | PRIdCGSIZE PRId64 |
| #define | CG_SIZE_MAX INT64_MAX |
| #define | FORTRAN_DEFAULT_INTEGER_C_INT64_T 0 |
Typedefs | |
| typedef int64_t | cgsize_t |
| typedef int | cgerr_t |
| typedef int | cgint_t |
| typedef double | cgid_t |
| typedef int | cgint_f |
| typedef CG_LONG_T | cglong_t |
| typedef CG_U_LONG_T | cgulong_t |
| #define CG_BUILD_HDF5 1 |
Definition at line 34 of file cgnstypes.h.
| #define CG_BUILD_LEGACY 0 |
Definition at line 35 of file cgnstypes.h.
| #define CG_BUILD_64BIT 1 |
Definition at line 36 of file cgnstypes.h.
| #define CG_BUILD_SCOPE 1 |
Definition at line 37 of file cgnstypes.h.
| #define CG_BUILD_BASESCOPE 0 |
Definition at line 38 of file cgnstypes.h.
| #define CG_BUILD_PARALLEL 0 |
Definition at line 39 of file cgnstypes.h.
| #define CG_BUILD_COMPLEX_C99_EXT 0 |
Definition at line 40 of file cgnstypes.h.
| #define CG_MAX_INT32 0x7FFFFFFF |
Definition at line 42 of file cgnstypes.h.
| #define CG_LONG_T int64_t |
Definition at line 46 of file cgnstypes.h.
| #define CG_U_LONG_T uint64_t |
Definition at line 47 of file cgnstypes.h.
| #define to_ADF_ID | ( | ID, | |
| ADF_ID | |||
| ) | memcpy(&(ADF_ID),&(ID),sizeof(hid_t)) |
Definition at line 55 of file cgnstypes.h.
| #define to_HDF_ID | ( | ADF_ID, | |
| ID | |||
| ) | memcpy(&(ID),&(ADF_ID),sizeof(hid_t)) |
Definition at line 56 of file cgnstypes.h.
| #define HDF5_HAVE_MULTI_DATASETS 0 |
Definition at line 60 of file cgnstypes.h.
| #define HDF5_HAVE_COLL_METADATA 0 |
Definition at line 64 of file cgnstypes.h.
| #define HDF5_HAVE_FILE_SPACE_STRATEGY 0 |
Definition at line 68 of file cgnstypes.h.
| #define CG_HAVE_STAT64_STRUCT 0 |
Definition at line 72 of file cgnstypes.h.
| #define CG_SIZEOF_SIZE 64 |
Definition at line 86 of file cgnstypes.h.
| #define CG_SIZE_DATATYPE "I8" |
Definition at line 87 of file cgnstypes.h.
| #define PRIdCGSIZE PRId64 |
Definition at line 88 of file cgnstypes.h.
| #define CG_SIZE_MAX INT64_MAX |
Definition at line 90 of file cgnstypes.h.
| #define FORTRAN_DEFAULT_INTEGER_C_INT64_T 0 |
Definition at line 104 of file cgnstypes.h.
| typedef int64_t cgsize_t |
Definition at line 89 of file cgnstypes.h.
Definition at line 98 of file cgnstypes.h.
Definition at line 99 of file cgnstypes.h.
Definition at line 100 of file cgnstypes.h.
Definition at line 108 of file cgnstypes.h.
Definition at line 112 of file cgnstypes.h.
| typedef CG_U_LONG_T cgulong_t |
Definition at line 113 of file cgnstypes.h.
1.8.13 on Sun Dec 14 2025
