Public Member Functions | List of all members
LagrangianParticleTrackerPlugin Class Reference
#include <LagrangianParticleTrackerPlugin.h>
Inheritance diagram for LagrangianParticleTrackerPlugin:
Collaboration diagram for LagrangianParticleTrackerPlugin:
 LagrangianParticleTrackerPlugin ()
const char * GetPluginName () override
 Returns the name for this plugin. More...
const char * GetPluginVersionString () override
 Returns the version for this plugin. More...
bool GetRequiredOnServer () override
 Returns true if this plugin is required on the server. More...
bool GetRequiredOnClient () override
 Returns true if this plugin is required on the client. More...
const char * GetRequiredPlugins () override
 Returns a ';' separated list of plugin names required by this plugin. More...
const char * GetDescription () override
 Returns a description of this plugin. More...
const char * GetEULA () override
 Returns EULA for the plugin, if any. More...
void GetBinaryResources (std::vector< std::string > &resources) override
 Provides access to binary resources compiled into the plugin. More...
void GetXMLs (std::vector< std::string > &xmls) override
 Obtain the server-manager configuration xmls, if any. More...
vtkClientServerInterpreterInitializer::InterpreterInitializationCallback GetInitializeInterpreterCallback () override
 Returns the callback function to call to initialize the interpretor for the new vtk/server-manager classes added by this plugin. More...
QObjectList interfaces () override
 Returns the list of ParaView-Interfaces provided by this plugin. More...
- Public Member Functions inherited from vtkPVGUIPluginInterface
virtual ~vtkPVGUIPluginInterface ()
- Public Member Functions inherited from vtkPVPlugin
 vtkPVPlugin ()
virtual ~vtkPVPlugin ()
const char * GetFileName ()
- Public Member Functions inherited from vtkPVServerManagerPluginInterface
virtual ~vtkPVServerManagerPluginInterface ()
virtual void GetXMLs (std::vector< std::string > &vtkNotUsed(xmls))=0
virtual bool GetEnsurePluginLoaded ()
 Return if the plugin should be ensured when using a proxy provided by the XMLs Useful for delayed load plugin. More...
- Public Types inherited from vtkPVPlugin
typedef bool(* EULAConfirmationCallback) (vtkPVPlugin *)
 Type for EULAConfirmationCallback. More...
- Static Public Member Functions inherited from vtkPVPlugin
static bool ImportPlugin (vtkPVPlugin *plugin)
 Used when import plugins programmatically. More...
static void SetEULAConfirmationCallback (EULAConfirmationCallback callback)
 Get/Set the static callback to call to confirm EULA. More...
static EULAConfirmationCallback GetEULAConfirmationCallback ()
- Protected Member Functions inherited from vtkPVPlugin
void SetFileName (const char *filename)
 Set the filename the plugin is loaded from, if any. More...
Definition at line 29 of file LagrangianParticleTrackerPlugin.h.
◆ LagrangianParticleTrackerPlugin()
LagrangianParticleTrackerPlugin::LagrangianParticleTrackerPlugin ( )
◆ GetPluginName()
const char* LagrangianParticleTrackerPlugin::GetPluginName ( )
inlineoverridevirtual
Implements vtkPVPlugin.
Definition at line 59 of file LagrangianParticleTrackerPlugin.h.
◆ GetPluginVersionString()
const char* LagrangianParticleTrackerPlugin::GetPluginVersionString ( )
Definition at line 65 of file LagrangianParticleTrackerPlugin.h.
◆ GetRequiredOnServer()
bool LagrangianParticleTrackerPlugin::GetRequiredOnServer ( )
Definition at line 71 of file LagrangianParticleTrackerPlugin.h.
◆ GetRequiredOnClient()
bool LagrangianParticleTrackerPlugin::GetRequiredOnClient ( )
Definition at line 77 of file LagrangianParticleTrackerPlugin.h.
◆ GetRequiredPlugins()
const char* LagrangianParticleTrackerPlugin::GetRequiredPlugins ( )
Definition at line 83 of file LagrangianParticleTrackerPlugin.h.
◆ GetDescription()
const char* LagrangianParticleTrackerPlugin::GetDescription ( )
Definition at line 89 of file LagrangianParticleTrackerPlugin.h.
◆ GetEULA()
const char* LagrangianParticleTrackerPlugin::GetEULA ( )
If none, this will return nullptr.
◆ GetBinaryResources()
void LagrangianParticleTrackerPlugin::GetBinaryResources ( std::vector< std::string > &  resources)
◆ GetXMLs()
void LagrangianParticleTrackerPlugin::GetXMLs ( std::vector< std::string > &  xmls)
override
◆ GetInitializeInterpreterCallback()
vtkClientServerInterpreterInitializer::InterpreterInitializationCallback LagrangianParticleTrackerPlugin::GetInitializeInterpreterCallback ( )
◆ interfaces()
QObjectList LagrangianParticleTrackerPlugin::interfaces ( )
Implements vtkPVGUIPluginInterface.
