A widget for array labeling. More...
#include <pqArrayListWidget.h>
Inherits QWidget.
Signals | |
| void | widgetModified () |
| fired whenever the state has been modified. More... | |
| pqArrayListWidget (QWidget *parent=nullptr) | |
| ~pqArrayListWidget () override=default | |
| bool | event (QEvent *e) override |
| overridden to handle QDynamicPropertyChangeEvent events. More... | |
| void | setHeaderLabel (const QString &label) |
| Set table header label. More... | |
| void | setMaximumRowCountBeforeScrolling (int size) |
| Set the maximum number of visible rows. More... | |
| void | setIconType (const QString &icon_type) |
| Set the icon type corresponding to the arrays. More... | |
Protected Slots | |
| void | updateProperty () |
| void | propertyChanged (const QString &pname) |
called in event() to handle change in a dynamic property with the given name. More... | |
pqArrayListWidget is intended to be used with 2-elements string properties. It creates a two-columns string table. First column is readonly, the second is editable.
It is useful to associate an editable label to each array, for array renaming for instance.
Definition at line 25 of file pqArrayListWidget.h.
| pqArrayListWidget::pqArrayListWidget | ( | QWidget * | parent = nullptr | ) |
overridedefault |
| void pqArrayListWidget::setHeaderLabel | ( | const QString & | label | ) |
It should match the Property name.
| void pqArrayListWidget::setMaximumRowCountBeforeScrolling | ( | int | size | ) |
Beyond this threshold, a scrollbar is added. Forwarded to the inner pqTableView.
| void pqArrayListWidget::setIconType | ( | const QString & | icon_type | ) |
signal |
protectedslot |
1.8.13 on Sat Dec 13 2025
