#include <pqBlockProxyWidget.h>
Public Slots | |
| void | apply () const override |
Public Slots inherited from pqProxyWidget | |
| bool | filterWidgets (bool show_advanced=false, const QString &filterText=QString()) |
| Updates the property widgets shown based on the filterText or show_advanced flag. More... | |
| void | showLinkedInteractiveWidget (int portIndex, bool show, bool changeFocus) |
| Show any interactive widget linked to a specific output port this proxyWdiget has. More... | |
| virtual void | apply () const |
| Accepts the property widget changes changes. More... | |
| void | reset () const |
| Cleans the property widget changes and resets the widgets. More... | |
| void | setView (pqView *) |
| Set the current view to use to show 3D widgets, if any for the panel. More... | |
| void | updatePanel () |
| Same as calling filterWidgets() with the arguments specified to the most recent call to filterWidgets(). More... | |
| virtual bool | restoreDefaults () |
| Restores application default proxy settings. More... | |
| void | saveAsDefaults () const |
| Saves settings as defaults for proxy. More... | |
| static pqPropertyWidget * | createWidgetForProperty (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parentObj) |
| create a widget for a property. More... | |
| pqBlockProxyWidget (vtkSMProxy *proxy, QString selector, QWidget *parent, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
| ~pqBlockProxyWidget () override | |
Public Member Functions inherited from pqProxyWidget | |
| pqProxyWidget (vtkSMProxy *proxy, const QStringList &properties, std::initializer_list< QString > defaultLabels, std::initializer_list< QString > advancedLabels, bool showHeadersFooters=true, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
| pqProxyWidget (vtkSMProxy *proxy, std::initializer_list< QString > defaultLabels, std::initializer_list< QString > advancedLabels, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
| pqProxyWidget (vtkSMProxy *proxy, const QStringList &properties, bool showHeadersFooters=true, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
| pqProxyWidget (vtkSMProxy *proxy, QWidget *parent, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
| pqProxyWidget (vtkSMProxy *proxy) | |
| ~pqProxyWidget () override | |
| Returns the proxy this panel shows. More... | |
| void | setApplyChangesImmediately (bool value) |
| When set to true, whenever the widget changes, the values are immediately pushed to the ServerManager property without having to wait for apply(). More... | |
| bool | applyChangesImmediately () const |
| bool | useDocumentationForLabels () const |
| When this is true, the panel uses a descriptive layout where the documentation for properties is used instead of their labels. More... | |
| void | showContextMenu (const QPoint &pt, pqPropertyWidget *propWidget) |
| const QSet< QString > & | defaultVisibilityLabels () const |
| pqProxyWidget shows widgets for properties in two configurations: basic and advanced. More... | |
| const QSet< QString > & | advancedVisibilityLabels () const |
Protected Slots | |
| void | onChangeFinished () override |
Protected Slots inherited from pqProxyWidget | |
| virtual void | onChangeFinished () |
| Called when a pqPropertyWidget fires changeFinished() signal. More... | |
Public Types inherited from pqProxyWidget | |
| enum | DocumentationType { NONE, USE_DESCRIPTION, USE_SHORT_HELP, USE_LONG_HELP } |
Signals inherited from pqProxyWidget | |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
Static Public Member Functions inherited from pqProxyWidget | |
| static QWidget * | newGroupLabelWidget (const QString &label, QWidget *parentWidget, const QList< QWidget *> &buttons=QList< QWidget *>()) |
| Returns a new widget that has the label and a h-line separator. More... | |
| static bool | useDocumentationForLabels (vtkSMProxy *proxy) |
| Returns true of the proxy provided has XML hints indicating that labels should use documentation instead of the XML label for the widgets in the UI. More... | |
| static QString | documentationText (vtkSMProperty *property, DocumentationType type=USE_DESCRIPTION) |
| Returns formatted (HTML or plainText) documentation for the property. More... | |
| static QString | documentationText (vtkSMProxy *property, DocumentationType type=USE_DESCRIPTION) |
| Returns formatted (HTML or plainText) documentation for the proxy. More... | |
| static DocumentationType | showProxyDocumentationInPanel (vtkSMProxy *proxy) |
| Returns true if the proxy has XML hints indicating that the panel should show a header label for the documentation. More... | |
Protected Member Functions inherited from pqProxyWidget | |
| void | showEvent (QShowEvent *event) override |
| void | hideEvent (QHideEvent *event) override |
| void | applyInternal () const |
Definition at line 12 of file pqBlockProxyWidget.h.
| pqBlockProxyWidget::pqBlockProxyWidget | ( | vtkSMProxy * | proxy, |
| QString | selector, | ||
| QWidget * | parent, | ||
| Qt::WindowFlags | flags = Qt::WindowFlags{} |
overrideslot |
overrideprotectedslot |
1.8.13 on Sun Dec 14 2025
