Public Slots | Signals | Public Member Functions | List of all members
pqCustomFilterManagerModel Class Reference
The pqCustomFilterManagerModel class stores the list of registered pipeline custom filter definitions. More...
#include <pqCustomFilterManagerModel.h>
Inherits QAbstractListModel.
Public Slots
void addCustomFilter (QString name)
 Adds a new custom filter definition to the model. More...
void removeCustomFilter (QString name)
 Removes a custom filter definition from the model. More...
void importCustomFiltersFromSettings ()
 Save/Load custom filters from pqSettings. More...
void exportCustomFiltersToSettings ()
Signals
void customFilterAdded (const QString &name)
 Emitted when a new custom filter definition is added to the model. More...
 pqCustomFilterManagerModel (QObject *parent=nullptr)
 ~pqCustomFilterManagerModel () override
QAbstractItemModel Methods
int rowCount (const QModelIndex &parent=QModelIndex()) const override
 Gets the number of rows for a given index. More...
QModelIndex index (int row, int column, const QModelIndex &parent=QModelIndex()) const override
 Gets a model index for a given location. More...
QVariant data (const QModelIndex &index, int role=Qt::DisplayRole) const override
 Gets the data for a given model index. More...
Qt::ItemFlags flags (const QModelIndex &index) const override
 Gets the flags for a given model index. More...
Index Mapping Methods
QString getCustomFilterName (const QModelIndex &index) const
 Gets the custom filter name for the given model index. More...
QModelIndex getIndexFor (const QString &filter) const
 Gets the model index for the given custom filter name. More...
The list is modified using the addCustomFilter and removeCustomFilter methods. When a new custom filter is added to the model a signal is emitted. This signal can be used to highlight the new custom filter.
Definition at line 30 of file pqCustomFilterManagerModel.h.
◆ pqCustomFilterManagerModel()
pqCustomFilterManagerModel::pqCustomFilterManagerModel ( QObject *  parent = nullptr)
◆ ~pqCustomFilterManagerModel()
pqCustomFilterManagerModel::~pqCustomFilterManagerModel ( )
override
◆ rowCount()
int pqCustomFilterManagerModel::rowCount ( const QModelIndex &  parent = QModelIndex()) const
override
Parameters
parentThe parent index.
Returns
The number of rows for the given index.
◆ index()
QModelIndex pqCustomFilterManagerModel::index ( int  row,
int  column,
) const
override
Parameters
rowThe row number.
columnThe column number.
Returns
A model index for the given location.
◆ data()
QVariant pqCustomFilterManagerModel::data ( const QModelIndex &  index,
int  role = Qt::DisplayRole
) const
override
Parameters
indexThe model index.
roleThe role to get data for.
Returns
The data for the given model index.
◆ flags()
Qt::ItemFlags pqCustomFilterManagerModel::flags ( const QModelIndex &  index) const
override
The flags for an item indicate if it is enabled, editable, etc.
Parameters
Returns
The flags for the given model index.
◆ getCustomFilterName()
QString pqCustomFilterManagerModel::getCustomFilterName ( const QModelIndex &  index) const
Parameters
indexThe model index to look up.
Returns
The custom filter definition name or an empty string.
◆ getIndexFor()
QModelIndex pqCustomFilterManagerModel::getIndexFor ( const QString &  filter) const
Parameters
filterThe custom filter definition name to look up.
Returns
The model index for the given name.
◆ addCustomFilter
void pqCustomFilterManagerModel::addCustomFilter ( QString  name)
slot
Parameters
nameThe name of the new custom filter definition.
◆ removeCustomFilter
void pqCustomFilterManagerModel::removeCustomFilter ( QString  name)
slot
Parameters
nameThe name of the custom filter definition.
◆ importCustomFiltersFromSettings
void pqCustomFilterManagerModel::importCustomFiltersFromSettings ( )
slot
◆ exportCustomFiltersToSettings
void pqCustomFilterManagerModel::exportCustomFiltersToSettings ( )
slot
◆ customFilterAdded
void pqCustomFilterManagerModel::customFilterAdded ( const QString &  name)
signal
Parameters
