#include <pqCustomViewpointButtonDialog.h>
Inherits QDialog.
| pqCustomViewpointButtonDialog (QWidget *parent, Qt::WindowFlags f, QStringList &toolTips, QStringList &configurations, QString ¤tConfig) | |
| Create and initialize the dialog. More... | |
| ~pqCustomViewpointButtonDialog () override | |
| void | setToolTipsAndConfigurations (const QStringList &toolTips, const QStringList &configs) |
| Set the list of tool tips and configurations. More... | |
| void | setToolTips (const QStringList &toolTips) |
| Set/get a list of tool tips, one for each button. More... | |
| QStringList | getToolTips () |
| void | setConfigurations (const QStringList &configs) |
| Set/get a list of camera configurations, one for each button. More... | |
| QStringList | getConfigurations () |
| void | setCurrentConfiguration (const QString &config) |
| Set/get the current camera configuration. More... | |
| QString | getCurrentConfiguration () |
Static Public Attributes | |
| static const QString | DEFAULT_TOOLTIP |
| Constant variable that contains the default name for the tool tips. More... | |
| static const int | MINIMUM_NUMBER_OF_ITEMS |
| Constant variable that defines the minimum number of items. More... | |
| static const int | MAXIMUM_NUMBER_OF_ITEMS |
| Constant variable that defines the maximum number of items. More... | |
Friends | |
| class | pqCustomViewpointButtonDialogUI |
Definition at line 33 of file pqCustomViewpointButtonDialog.h.
| pqCustomViewpointButtonDialog::pqCustomViewpointButtonDialog | ( | QWidget * | parent, |
| Qt::WindowFlags | f, | ||
| QStringList & | toolTips, | ||
| QStringList & | configurations, | ||
| QString & | currentConfig | ||
| void pqCustomViewpointButtonDialog::setToolTipsAndConfigurations | ( | const QStringList & | toolTips, |
| const QStringList & | configs | ||
This is the preferred way of settings these as it supports changing the number of items.
| void pqCustomViewpointButtonDialog::setToolTips | ( | const QStringList & | toolTips | ) |
The number of items in the toolTips list must match the current number of tooltips being shown. Use setToolTipsAndConfigurations to change the number of items.
| QStringList pqCustomViewpointButtonDialog::getToolTips | ( | ) |
| void pqCustomViewpointButtonDialog::setConfigurations | ( | const QStringList & | configs | ) |
The number of items in configs must match the current number of configs. Use setToolTipsAndConfigurations to change the number of items.
| QStringList pqCustomViewpointButtonDialog::getConfigurations | ( | ) |
| void pqCustomViewpointButtonDialog::setCurrentConfiguration | ( | const QString & | config | ) |
| QString pqCustomViewpointButtonDialog::getCurrentConfiguration | ( | ) |
friend |
Definition at line 110 of file pqCustomViewpointButtonDialog.h.
Definition at line 49 of file pqCustomViewpointButtonDialog.h.
Definition at line 54 of file pqCustomViewpointButtonDialog.h.
Definition at line 59 of file pqCustomViewpointButtonDialog.h.
1.8.13 on Sat Dec 13 2025
