QAbstractItemModel implementation for vtkDataAssembly. More...
#include <pqDataAssemblyTreeModel.h>
Inherits QAbstractItemModel.
| enum | RoleProperties { Standard, Inherited, InheritedUntilOverridden } |
| Supported role properties. More... | |
Signals | |
| void | modelDataChanged (int role) |
This signal is fired in setData if the data is changed. More... | |
| pqDataAssemblyTreeModel (QObject *parent=nullptr) | |
| ~pqDataAssemblyTreeModel () override | |
| void | setDataAssembly (vtkDataAssembly *assembly) |
| Get/Set the vtkDataAssembly to represent in this model. More... | |
| vtkDataAssembly * | dataAssembly () const |
| void | setUserCheckable (bool) |
| Get whether the model is user-checkable. More... | |
| bool | userCheckable () const |
| int | nodeId (const QModelIndex &idx) const |
| Given a QModelIndex, returns the vtkDataAssembly node id, if any. More... | |
| QList< int > | nodeId (const QModelIndexList &idxes) const |
| QModelIndex | index (int nodeId) const |
| Get a node id, returns the QModelIndex for the same. More... | |
| QModelIndexList | index (const QList< int > &nodeIds) const |
| void | setCheckedNodes (const QStringList &paths) |
| Get/Set the check state for Qt::Checked for nodes selected using the path names specified. More... | |
| QStringList | checkedNodes (bool leafNodesOnly=false) const |
| void | setRoleProperty (int role, RoleProperties property) |
| Set properties for custom roles. More... | |
| RoleProperties | roleProperty (int role) const |
| bool | setData (const QList< QPair< QString, QVariant >> &values, int role) |
| Get/Set the values for a specific role using selectors. More... | |
| QList< QPair< QString, QVariant > > | data (int role) const |
| int | columnCount (const QModelIndex &parent=QModelIndex()) const override |
| QAbstractItemModel interface implementation. More... | |
| int | rowCount (const QModelIndex &parent=QModelIndex()) const override |
| QModelIndex | index (int row, int column, const QModelIndex &parent=QModelIndex()) const override |
| QModelIndex | parent (const QModelIndex &index=QModelIndex()) const override |
| QVariant | data (const QModelIndex &index, int role) const override |
| Qt::ItemFlags | flags (const QModelIndex &index) const override |
| bool | setData (const QModelIndex &index, const QVariant &value, int role) override |
| static int | GetIsDerivedRole (int role) |
For custom roles, use this function to convert that role into a role that can be used in data() to get a boolean indicating if the value is derived or explicitly set. More... | |
pqDataAssemblyTreeModel builds a tree-model from a vtkDataAssembly. The vtkDataAssembly to shown is set using setDataAssembly. To allow user-settable check-states, use setUserCheckable(true).
One can store additional data associated with nodes using custom roles (Qt::UserRole). For custom roles, one can define how a value for that specific role get inherited by child nodes or overridden when set on a parent node. This is done using setRoleProperty.
Definition at line 28 of file pqDataAssemblyTreeModel.h.
Standard implies no special handling i.e. the role does not affect the value of the value for child nodes in the hierarchy. Inherited means for any node, if a value for this role is not explicitly specified, then it is inherited from its parent node. Likewise, if one sets a explicitly on a node (using setData), the it overrides values for this role on all children recursively. InheritedUntilOverridden is similar to Inherited except that the recursion down the subtree stops when a child node with an explicitly set value is encountered.
| Enumerator | |
| Standard | |
| Inherited | |
| InheritedUntilOverridden | |
Definition at line 108 of file pqDataAssemblyTreeModel.h.
| pqDataAssemblyTreeModel::pqDataAssemblyTreeModel | ( | QObject * | parent = nullptr | ) |
| void pqDataAssemblyTreeModel::setDataAssembly | ( | vtkDataAssembly * | assembly | ) |
| vtkDataAssembly* pqDataAssemblyTreeModel::dataAssembly | ( | ) | const |
| void pqDataAssemblyTreeModel::setUserCheckable | ( | bool | ) |
Definition at line 48 of file pqDataAssemblyTreeModel.h.
-1 is returned for invalid index.
| QModelIndex pqDataAssemblyTreeModel::index | ( | int | nodeId | ) | const |
| void pqDataAssemblyTreeModel::setCheckedNodes | ( | const QStringList & | paths | ) |
setCheckedNodes has effect as setData(.., Qt::CheckStateRole), only differing in how the values are specified. For setCheckedNodes, one only lists the selectors for checked nodes, while setData accept pairs where the first value is the selector while the second value is the check state.
checkedNodes() may not returns exactly the same paths passed to setCheckedNodes even if the check-states were not changed in between the two calls. leafNodesOnly controls whether the returned paths are leaf nodes only or all nodes that are checked.| QStringList pqDataAssemblyTreeModel::checkedNodes | ( | bool | leafNodesOnly = false | ) | const |
checkedNodes() may not returns exactly the same paths passed to setCheckedNodes even if the check-states were not changed in between the two calls. leafNodesOnly controls whether the returned paths are leaf nodes only or all nodes that are checked.For custom roles, use this function to convert that role into a role that can be used in data() to get a boolean indicating if the value is derived or explicitly set.
Definition at line 95 of file pqDataAssemblyTreeModel.h.
| void pqDataAssemblyTreeModel::setRoleProperty | ( | int | role, |
| RoleProperties | property | ||
If none specified, Standard is assumed. For Qt::CheckStateRole, it is initialized to Inherited.
| RoleProperties pqDataAssemblyTreeModel::roleProperty | ( | int | role | ) | const |
| bool pqDataAssemblyTreeModel::setData | ( | const QList< QPair< QString, QVariant >> & | values, |
| int | role | ||
The values are specified as a list of pairs which pair comprising of a selector and the associated value for that selector. This model is not capable of generating advanced selectors, so data() will simply return paths as selectors. setData can use any for for selector specification supported by the underlying vtkDataAssembly.
This model does not cache set values. When setData is called, nodes matching the selectors are immediately located and updated. Hence, if this method is called before any assembly is set, the values will be lost. In this case, setData will return false.
| QList<QPair<QString, QVariant> > pqDataAssemblyTreeModel::data | ( | int | role | ) | const |
signal |
setData can result in multiple calls to dataChanged signal as the data is updated on nodes in the hierarchy. This signal is fired only once for setData call irrespective of how many internal nodes are updated.
1.8.13 on Sun Dec 14 2025
