pqDisplayColorWidget is a widget that can be used to select the array to with for representations (also known as displays). More...
#include <pqDisplayColorWidget.h>
Inherits QWidget.
| typedef QPair< int, QString > | ValueType |
Public Slots | |
| void | setRepresentationText (const QString &text) |
| set representation type. More... | |
| void | queryCurrentSelectedArray () |
| Query the currently selected array from the property. More... | |
| void | setRepresentation (pqDataRepresentation *display, int selectedPropertiesType) |
| Set the representation to control the scalar coloring properties on. More... | |
| void | setRepresentation (pqDataRepresentation *display) |
Signals | |
| void | arraySelectionChanged () |
| fired to indicate the array-name changed. More... | |
| void | representationTextChanged (const QString &text) |
| fired to indicate the representation type changed, allowing us to update. More... | |
| pqDisplayColorWidget (QWidget *parent=nullptr) | |
| ~pqDisplayColorWidget () override | |
| ValueType | arraySelection () const |
| Get/Set the array name as pair (association-number, arrayname). More... | |
| QString | getCurrentText () const |
| int | componentNumber () const |
| Get/Set the component number (-1 == magnitude). More... | |
| vtkSMViewProxy * | viewProxy () const |
| Returns the view proxy corresponding to the set representation, if any. More... | |
| QString | representationText () const |
| Returns the selected representation type as a string. More... | |
| static void | hideScalarBarsIfNotNeeded (vtkSMViewProxy *view, std::vector< vtkSMProxy *> luts) |
| Hides the scalar bars if not needed. More... | |
| static void | updateScalarBarVisibility (vtkSMViewProxy *view, vtkSMProxy *reprProxy, int selectedPropertiesType=0) |
Updates the scalar bar visibility of the representation reprProxy in view. More... | |
| void | setArraySelection (const ValueType &) |
| Update the UI to show the selected array. More... | |
| void | setComponentNumber (int) |
| Update the UI to show the selected component. More... | |
Properties | |
| QString | representationText |
Friends | |
| class | PropertyLinksConnection |
It comprises of two combo-boxes, one for the array name, and another for component number. To use, set the representation using setRepresentation(..). If the representation has appropriate properties, this widget will allow users to select the array name.
Definition at line 31 of file pqDisplayColorWidget.h.
| typedef QPair<int, QString> pqDisplayColorWidget::ValueType |
Definition at line 38 of file pqDisplayColorWidget.h.
| pqDisplayColorWidget::pqDisplayColorWidget | ( | QWidget * | parent = nullptr | ) |
| ValueType pqDisplayColorWidget::arraySelection | ( | ) | const |
Definition at line 47 of file pqDisplayColorWidget.h.
| int pqDisplayColorWidget::componentNumber | ( | ) | const |
| vtkSMViewProxy* pqDisplayColorWidget::viewProxy | ( | ) | const |
The behavior of the scalar bar visibility is dependent of the general settings.
Definition at line 74 of file pqDisplayColorWidget.h.
signal |
signal |
slot |
inlineslot |
Definition at line 93 of file pqDisplayColorWidget.h.
slot |
slot |
friend |
Definition at line 183 of file pqDisplayColorWidget.h.
readwrite |
Definition at line 34 of file pqDisplayColorWidget.h.
1.8.13 on Sun Dec 14 2025
