Extends pqDoubleSliderWidget to use it with a range of doubles : provides control on min/max, resolution and on line edit validator. More...
#include <pqDoubleRangeWidget.h>
Public Slots | |
| void | setMinimum (double) |
| void | setMaximum (double) |
| void | setResolution (int) |
Public Slots inherited from pqDoubleSliderWidget | |
| void | setValue (double val) |
| set the value More... | |
| void | setNotation (pqDoubleLineEdit::RealNumberNotation _notation) |
| Set the notation used to display the number. More... | |
| void | setPrecision (int precision) |
| Set the precision used to display the number. More... | |
| void | setUseGlobalPrecisionAndNotation (bool value) |
| Set whether to use global precision and notation values. More... | |
| pqDoubleRangeWidget (QWidget *parent=nullptr) | |
| constructor requires the proxy, property More... | |
| ~pqDoubleRangeWidget () override | |
| pqDoubleRangeWidget (QWidget *parent, double min, double max, double value) | |
| double | minimum () const |
| double | maximum () const |
| int | resolution () const |
Public Member Functions inherited from pqDoubleSliderWidget | |
| pqDoubleSliderWidget (QWidget *parent=nullptr) | |
| ~pqDoubleSliderWidget () override | |
| double | value () const |
| get the value More... | |
| pqDoubleLineEdit::RealNumberNotation | notation () const |
| Return the notation used to display the number. More... | |
| int | precision () const |
| Return the precision used to display the number. More... | |
| bool | useGlobalPrecisionAndNotation () const |
useGlobalPrecisionAndNotation indicates if the pqDoubleLineEdit used by this widget should use global precision and notation values instead of the parameters specified on this instance. More... | |
| int | valueToSliderPos (double val) override |
| double | sliderPosToValue (int pos) override |
Protected Member Functions inherited from pqDoubleSliderWidget | |
| void | setValidator (QDoubleValidator *validator) |
| const QDoubleValidator * | validator () const |
| void | setSliderRange (int min, int max) |
| void | updateSlider () |
Properties | |
| double | minimum |
| double | maximum |
| int | resolution |
Properties inherited from pqDoubleSliderWidget | |
| double | value |
| pqDoubleLineEdit::RealNumberNotation | notation |
| int | precision |
| bool | useGlobalPrecisionAndNotation |
Signals inherited from pqDoubleSliderWidget | |
| void | valueChanged (double) |
| signal the value changed More... | |
| void | valueEdited (double) |
| signal the value was edited this means the user is done changing text or the user is done moving the slider. More... | |
Definition at line 15 of file pqDoubleRangeWidget.h.
| pqDoubleRangeWidget::pqDoubleRangeWidget | ( | QWidget * | parent = nullptr | ) |
| double pqDoubleRangeWidget::minimum | ( | ) | const |
| double pqDoubleRangeWidget::maximum | ( | ) | const |
| int pqDoubleRangeWidget::resolution | ( | ) | const |
slot |
slot |
slot |
Reimplemented from pqDoubleSliderWidget.
readwrite |
Definition at line 18 of file pqDoubleRangeWidget.h.
readwrite |
Definition at line 19 of file pqDoubleRangeWidget.h.
readwrite |
Definition at line 20 of file pqDoubleRangeWidget.h.
1.8.13 on Sun Dec 14 2025
