Signals | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
pqExpandableTableView Class Reference
pqExpandableTableView extends pqTableView to add support for the following features: More...
#include <pqExpandableTableView.h>
Inheritance diagram for pqExpandableTableView:
Collaboration diagram for pqExpandableTableView:
Signals
void editPastLastRow ()
 signal fired when the user edits past the last row. More...
 pqExpandableTableView (QWidget *parent=nullptr)
 ~pqExpandableTableView () override
void setPasteEnabled (bool enable)
 Enable pasting in table from clipboard. More...
- Public Member Functions inherited from pqTableView
 pqTableView (QWidget *parent=nullptr)
 ~pqTableView () override
void setMaximumRowCountBeforeScrolling (int val)
 Set the maximum number of rows beyond which this view should show a vertical scroll bar. More...
int maximumRowCountBeforeScrolling () const
void setMinimumRowCount (int val)
 Set the number of rows to use as the minimum to determine the size of the widget when there are fewer or no rows. More...
int minimumRowCount () const
void setPadding (int val)
 Set the number of rows to always pad the widget with. More...
int padding () const
void setModel (QAbstractItemModel *model) override
 Overridden to ensure the view updates its size as rows are added/removed. More...
void setRootIndex (const QModelIndex &index) override
QSize sizeHint () const override
 Overridden to report size as per the state of this pqTableView. More...
QSize minimumSizeHint () const override
bool eventFilter (QObject *watched, QEvent *evt) override
 Overridden to handle events from QScrollBar. More...
void wheelEvent (QWheelEvent *event) override
 Overridden to eat wheel events unless this->hasFocus(). More...
QModelIndex moveCursor (CursorAction cursorAction, Qt::KeyboardModifiers modifiers) override
 Working together with logic in closeEditor(). More...
void closeEditor (QWidget *editor, QAbstractItemDelegate::EndEditHint hint) override
 Overridden to set MoveToNextEditableItem so that moveCursor() can skip non-editable items. More...
void keyPressEvent (QKeyEvent *event) override
 Overridden to capture Ctrl-V for pasting table data into the table. More...
bool PasteEnabled
- Properties inherited from pqTableView
 Maximum number of rows beyond which this view should show a vertical scroll bar. More...
int minimumRowCount
 The number of rows to use as the minimum to determine the size of the widget when there are fewer or no rows. More...
int padding
 The number of rows to always pad the widget with. More...
Definition at line 21 of file pqExpandableTableView.h.
◆ pqExpandableTableView()
pqExpandableTableView::pqExpandableTableView ( QWidget *  parent = nullptr)
◆ ~pqExpandableTableView()
pqExpandableTableView::~pqExpandableTableView ( )
override
◆ setPasteEnabled()
void pqExpandableTableView::setPasteEnabled ( bool  enable)
Default is true.
◆ editPastLastRow
void pqExpandableTableView::editPastLastRow ( )
signal
Handlers can add a new row to the table, if needed, to allow used to edit expandable tables with ease.
◆ moveCursor()
QModelIndex pqExpandableTableView::moveCursor ( CursorAction  cursorAction,
This methods makes it possible to skip past non-editable items.
◆ closeEditor()
void pqExpandableTableView::closeEditor ( QWidget *  editor,
Also if moved past the last rows/last column, this will fire the editPastLastRow() signal.
◆ keyPressEvent()
void pqExpandableTableView::keyPressEvent ( QKeyEvent *  event)
◆ PasteEnabled
bool pqExpandableTableView::PasteEnabled
Definition at line 63 of file pqExpandableTableView.h.
