pqExpressionsManagerDialog is a dialog class to edit and export expressions. More...
#include <pqExpressionsDialog.h>
Inherits QDialog.
Signals | |
| void | expressionSelected (const QString &expr) |
| Emitted after click on "UseCurrent" button. More... | |
| pqExpressionsManagerDialog (QWidget *parent, const QString &group="") | |
| ~pqExpressionsManagerDialog () override | |
Protected Slots | |
| void | addNewExpression () |
| Add a new empty expression in the current group, and select it. More... | |
| void | removeSelectedExpressions () |
| Remove the selected expressions. More... | |
| void | removeAllExpressions () |
| Remove all expressions. More... | |
| void | onClose () |
| Save window state and store inner model to settings. More... | |
| void | updateUi () |
| Update the dialog according to the current state. More... | |
| void | filterGroup () |
| Update table filtering based on group. More... | |
| void | onUseCurrent () |
| Triggered by "UseCurrent" button. More... | |
| void | keyReleaseEvent (QKeyEvent *event) override |
| Reimplemented to handle del. More... | |
| void | save () |
| Save expressions to settings. More... | |
| void | exportToFile () |
| Export / import expressions to (respectively from) file. More... | |
| bool | importFromFile () |
Expressions are loaded from the settings, and are saved on close. Expressions can be exported to a *.json file. When importing a *.json file, new expressions are appended to the current list. Already existing expressions are not duplicated.
Expected formatting of the file:
* "version": "<version>",
* "Expressions": [
* "Expression": <expressions string>,
* "Name": "<expression name>",
* "Group": "<expression_group>"
Definition at line 35 of file pqExpressionsDialog.h.
| pqExpressionsManagerDialog::pqExpressionsManagerDialog | ( | QWidget * | parent, |
| const QString & | group = "" |
signal |
Argument is the first selected expression.
protectedslot |
If there is already such empty expression, use it instead of adding a new one.
protectedslot |
protectedslot |
protectedslot |
protectedslot |
Enable / disables buttons based on selection.
protectedslot |
protectedslot |
Open a dialog to get the *.json file.
protectedslot |
protectedslot |
Emit signal expressionSelected().
overrideprotectedslot |
protectedslot |
1.8.13 on Sun Dec 14 2025
