: A custom QSortFilterProxyModel to do extended search. More...
#include <pqExtendedSortFilterProxyModel.h>
Inherits QSortFilterProxyModel.
| pqExtendedSortFilterProxyModel (QObject *parent) | |
| ~pqExtendedSortFilterProxyModel () override=default | |
| void | update () |
| Triggers an update of the sort filter model. More... | |
| void | setRequest (const QString &request) |
| Set the user requests. More... | |
| void | setRequest (int role, const QVariant &value) |
| Set the user request for the given ItemRole. More... | |
| void | clearRequests () |
| Clear user requests. More... | |
| void | setExclusion (int role, const QVariant &value) |
| Set the Exclusions list. More... | |
| void | clearExclusions () |
| Clear the exclusion list. More... | |
| bool | filterAcceptsRow (int sourceRow, const QModelIndex &sourceParent) const override |
| Returns false if row is excluded. More... | |
| bool | lessThan (const QModelIndex &left, const QModelIndex &right) const override |
| Sort elements depending on their priority: More... | |
: Allow to do extended search in a model, using different ItemRole.
Different kind of matches can be used to filter elements:
Items are sorted per match kind: exact match first, then standard match and finally user match. Within a match kind, alphabetical sort is used.
Items matching an Exlusion criteria are always hidden, regardless of the requests.
Definition at line 24 of file pqExtendedSortFilterProxyModel.h.
| pqExtendedSortFilterProxyModel::pqExtendedSortFilterProxyModel | ( | QObject * | parent | ) |
overridedefault |
| void pqExtendedSortFilterProxyModel::setRequest | ( | const QString & | request | ) |
Set the user string request for default role.
This is used for match operations. Matching items are visible (if not excluded).
filterRole is intended to be Qt::DisplayRole (default) or at least a role for QString data.
Items matching this value will be shown. This acts as a "white list"
see clearUserRequests(), setExclusion()
| void pqExtendedSortFilterProxyModel::clearRequests | ( | ) |
Remove custom role checks. Note that the main request is not touched.
Set an exclusion rule for ItemRole.
Items matching this value will always be hidden.
see clearExclusions(), setUserRequest()
| void pqExtendedSortFilterProxyModel::clearExclusions | ( | ) |
| void pqExtendedSortFilterProxyModel::update | ( | ) |
Returns true if every sub part of the Request has a match. Returns false otherwise.
At same priority, it uses alphanumeric comparison.
1.8.13 on Sun Dec 14 2025
