Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | Properties | List of all members
pqFileChooserWidget Class Reference
input widget for files More...
#include <pqFileChooserWidget.h>
Inherits QWidget.
Collaboration diagram for pqFileChooserWidget:
Signals
void filenamesChanged (const QStringList &)
 Signal emitted when the filename changes. More...
void filenameChanged (const QString &)
 pqFileChooserWidget (QWidget *p=nullptr)
 constructor More...
 ~pqFileChooserWidget () override
 destructor More...
QStringList filenames () const
 get the filename More...
void setFilenames (const QStringList &)
 set the filename More...
QString extension ()
 get the file extension for the file dialog More...
void setExtension (const QString &)
 set the file extension for the file dialog More...
bool forceSingleFile ()
 flag specifying whether this widget should accept multiple files More...
void setForceSingleFile (bool flag)
bool useDirectoryMode ()
 flag specifying whether this widget should use directory mode More...
void setUseDirectoryMode (bool flag)
bool acceptAnyFile ()
 flag specifying whether this widget should accept any file More...
void setAcceptAnyFile (bool flag)
void setServer (pqServer *server)
 set server to work on. More...
pqServerserver ()
QString singleFilename () const
 Convenience functions for when using only a single file (see forceSingleFile property). More...
void setSingleFilename (const QString &)
void setTitle (const QString &ttle)
 Get/set the title to use. More...
const QString & title () const
static QStringList splitFilenames (const QString &filesString)
 Converts between a list of file names and delimited string of filenames (which is shown in the line edit box). More...
static QString joinFilenames (const QStringList &filesList)
Protected Slots
void chooseFile ()
 Called when the user hits the choose file button. More...
void handleFileLineEditChanged (const QString &fileString)
 Respond to changes with the filename in the line edit box. More...
void emitFilenamesChanged (const QStringList &fileList)
 Takes a string with delimited files and emits the filenamesChanged and filenameChanged signals. More...
QString Extension
QLineEdit * LineEdit
pqServerServer
bool ForceSingleFile
bool UseDirectoryMode
bool AcceptAnyFile
QStringList FilenameList
bool UseFilenameList
QString Title
Properties
QString extension
bool acceptAnyFile
pqFileChooserWidget which consists of a tool button and a line edit hitting the tool button will bring up a file dialog, and the chosen file will be put in the line edit
Definition at line 26 of file pqFileChooserWidget.h.
◆ pqFileChooserWidget()
pqFileChooserWidget::pqFileChooserWidget ( QWidget *  p = nullptr)
constructor
◆ ~pqFileChooserWidget()
pqFileChooserWidget::~pqFileChooserWidget ( )
override
destructor
◆ filenames()
QStringList pqFileChooserWidget::filenames ( ) const
get the filename
◆ setFilenames()
void pqFileChooserWidget::setFilenames ( const QStringList &  )
set the filename
◆ singleFilename()
QString pqFileChooserWidget::singleFilename ( ) const
◆ setSingleFilename()
void pqFileChooserWidget::setSingleFilename ( const QString &  )
◆ extension()
QString pqFileChooserWidget::extension ( )
◆ setExtension()
void pqFileChooserWidget::setExtension ( const QString &  )
◆ forceSingleFile()
bool pqFileChooserWidget::forceSingleFile ( )
inline
Definition at line 79 of file pqFileChooserWidget.h.
◆ setForceSingleFile()
void pqFileChooserWidget::setForceSingleFile ( bool  flag)
inline
Definition at line 80 of file pqFileChooserWidget.h.
◆ useDirectoryMode()
bool pqFileChooserWidget::useDirectoryMode ( )
inline
Definition at line 89 of file pqFileChooserWidget.h.
◆ setUseDirectoryMode()
void pqFileChooserWidget::setUseDirectoryMode ( bool  flag)
inline
Definition at line 90 of file pqFileChooserWidget.h.
◆ acceptAnyFile()
bool pqFileChooserWidget::acceptAnyFile ( )
inline
Definition at line 99 of file pqFileChooserWidget.h.
◆ setAcceptAnyFile()
void pqFileChooserWidget::setAcceptAnyFile ( bool  flag)
inline
Definition at line 100 of file pqFileChooserWidget.h.
◆ setTitle()
void pqFileChooserWidget::setTitle ( const QString &  ttle)
inline
If an empty string is specified, a default one is created.
Definition at line 111 of file pqFileChooserWidget.h.
◆ title()
const QString& pqFileChooserWidget::title ( ) const
inline
Definition at line 112 of file pqFileChooserWidget.h.
◆ setServer()
void pqFileChooserWidget::setServer ( pqServer server)
If server is nullptr, a local file dialog is used
◆ server()
pqServer* pqFileChooserWidget::server ( )
◆ splitFilenames()
static QStringList pqFileChooserWidget::splitFilenames ( const QString &  filesString)
inlinestatic
Definition at line 126 of file pqFileChooserWidget.h.
◆ joinFilenames()
static QString pqFileChooserWidget::joinFilenames ( const QStringList &  filesList)
inlinestatic
Definition at line 130 of file pqFileChooserWidget.h.
◆ filenamesChanged
void pqFileChooserWidget::filenamesChanged ( const QStringList &  )
signal
The single string version is a convenience for when you are only grabbing the first file anyway.
◆ filenameChanged
void pqFileChooserWidget::filenameChanged ( const QString &  )
signal
◆ chooseFile
void pqFileChooserWidget::chooseFile ( )
protectedslot
◆ handleFileLineEditChanged
void pqFileChooserWidget::handleFileLineEditChanged ( const QString &  fileString)
protectedslot
◆ emitFilenamesChanged()
void pqFileChooserWidget::emitFilenamesChanged ( const QStringList &  fileList)
◆ Extension
QString pqFileChooserWidget::Extension
Definition at line 151 of file pqFileChooserWidget.h.
◆ LineEdit
QLineEdit* pqFileChooserWidget::LineEdit
Definition at line 152 of file pqFileChooserWidget.h.
◆ Server
pqServer* pqFileChooserWidget::Server
Definition at line 153 of file pqFileChooserWidget.h.
◆ ForceSingleFile
bool pqFileChooserWidget::ForceSingleFile
Definition at line 154 of file pqFileChooserWidget.h.
◆ UseDirectoryMode
bool pqFileChooserWidget::UseDirectoryMode
Definition at line 155 of file pqFileChooserWidget.h.
◆ AcceptAnyFile
bool pqFileChooserWidget::AcceptAnyFile
Definition at line 156 of file pqFileChooserWidget.h.
◆ FilenameList
QStringList pqFileChooserWidget::FilenameList
Definition at line 157 of file pqFileChooserWidget.h.
◆ UseFilenameList
bool pqFileChooserWidget::UseFilenameList
Definition at line 158 of file pqFileChooserWidget.h.
◆ Title
QString pqFileChooserWidget::Title
Definition at line 159 of file pqFileChooserWidget.h.
Property Documentation
◆ filenames
readwrite
Definition at line 29 of file pqFileChooserWidget.h.
◆ singleFilename
readwrite
Definition at line 30 of file pqFileChooserWidget.h.
◆ extension
readwrite
Definition at line 31 of file pqFileChooserWidget.h.
◆ useDirectoryMode
readwrite
Definition at line 32 of file pqFileChooserWidget.h.
◆ forceSingleFile
readwrite
Definition at line 33 of file pqFileChooserWidget.h.
◆ acceptAnyFile
readwrite
Definition at line 34 of file pqFileChooserWidget.h.
