pqInterfaceTracker is used by ParaView components to locate interface-implementations.
#include <pqInterfaceTracker.h>
Inherits QObject.
These implementations can be either those loaded from plugins or registered explicitly using addInterface/removeInterface API. In previous versions of ParaView, this role was performed by the pqPluginManager class itself.
Definition at line 19 of file pqInterfaceTracker.h.
◆ pqInterfaceTracker()
pqInterfaceTracker::pqInterfaceTracker |
QObject * |
parent = nullptr | ) |
◆ ~pqInterfaceTracker()
pqInterfaceTracker::~pqInterfaceTracker |
◆ interfaces() [1/2]
QObjectList pqInterfaceTracker::interfaces |
const |
◆ interfaces() [2/2]
template<class T >
QList<T> pqInterfaceTracker::interfaces |
const |
Returns all interfaces that have been loaded/registered that are of the requested type.
Definition at line 38 of file pqInterfaceTracker.h.
◆ addInterface()
void pqInterfaceTracker::addInterface |
QObject * |
iface | ) |
add an extra interface.
these interfaces are appended to the ones loaded from plugins
◆ removeInterface()
void pqInterfaceTracker::removeInterface |
QObject * |
iface | ) |
remove an extra interface
◆ initialize()
void pqInterfaceTracker::initialize |
initializes the tracker using existing plugins.
◆ interfaceRegistered
void pqInterfaceTracker::interfaceRegistered |
QObject * |
iface | ) |
signal |
fired every time an interface is registered either from a plugin on manually.
◆ onPluginLoaded()
void pqInterfaceTracker::onPluginLoaded |
vtkObject * |
unsigned |
long, |
void * |
calldata |
Callback when a plugin is loaded.
We locate and load any interafaces defined in the plugin.
◆ Interfaces
QObjectList pqInterfaceTracker::Interfaces |
◆ RegisteredInterfaces
QObjectList pqInterfaceTracker::RegisteredInterfaces |
◆ ObserverID
unsigned long pqInterfaceTracker::ObserverID |
