pqMaterialEditor is a widget that can be used to edit the OSPRay materials. More...
#include <pqMaterialEditor.h>
Inherits QWidget.
| enum | ExtendedItemDataRole { ExtendedItemDataRole::PropertyValue = Qt::UserRole + 1 } |
| Strong type extension of the existing Qt::ItemDataRole. More... | |
| pqMaterialEditor (QWidget *parent=nullptr, QDockWidget *dockWidget=nullptr) | |
| ~pqMaterialEditor () override | |
| void | updateMaterialList () |
| Clear the editor and fill the editor with the current created materials. More... | |
| QString | currentMaterialName () |
| Return the name of the current selected material. More... | |
| std::vector< std::string > | availableParameters () |
| Return the list of the available OSPRay parameters for the current material. More... | |
Protected Slots | |
| void | updateCurrentMaterial (const std::string &) |
| void | updateCurrentMaterialWithIndex (int index) |
| void | loadMaterials () |
| void | addMaterial () |
| void | removeMaterial () |
| void | attachMaterial () |
| void | saveMaterials () |
| void | addProperty () |
| void | propertyChanged (const QModelIndex &topLeft, const QModelIndex &bottomRight) |
| std::string | generateValidMaterialName (const std::string &name) |
| Return a unique material name given a desired name. More... | |
| void | showEvent (QShowEvent *event) override |
| Overriden to warn user when material editor is not usable. More... | |
Friends | |
| class | pqInternals |
This widget allows you to create or remove an OSPRay material. Then, you can customize this material by adding or removing properties, such as the color, the roughness, the textures... depending on the available properties that you can see in vtkOSPRayMaterialLibrary. Texture format supported are *.png, *.jpg, *.bmp and *.ppm.
Definition at line 26 of file pqMaterialEditor.h.
strong |
This is used to store the QVariant value for the properties
| Enumerator | |
| PropertyValue | |
Definition at line 54 of file pqMaterialEditor.h.
| pqMaterialEditor::pqMaterialEditor | ( | QWidget * | parent = nullptr, |
| QDockWidget * | dockWidget = nullptr |
| void pqMaterialEditor::updateMaterialList | ( | ) |
| QString pqMaterialEditor::currentMaterialName | ( | ) |
| std::vector<std::string> pqMaterialEditor::availableParameters | ( | ) |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
Checks for all the already existing materials and if one has the same name, this function appends the suffix _X where X is the next unique integer identifier.
friend |
Definition at line 93 of file pqMaterialEditor.h.
1.8.13 on Sun Dec 14 2025
