Public Member Functions | Protected Attributes | List of all members
pqNonOrthogonalAutoStartImplementation Class Reference
#include <pqNonOrthogonalAutoStartImplementation.h>
Inheritance diagram for pqNonOrthogonalAutoStartImplementation:
Collaboration diagram for pqNonOrthogonalAutoStartImplementation:
 pqNonOrthogonalAutoStartImplementation (QObject *p=nullptr)
 ~pqNonOrthogonalAutoStartImplementation () override
void startup () override
 Called once after the ParaView starts. More...
void shutdown () override
 Called once before the program shuts down. More...
- Public Member Functions inherited from pqAutoStartInterface
virtual ~pqAutoStartInterface ()
pqNonOrthogonalAutoStart * UserImplementation
- Protected Member Functions inherited from pqAutoStartInterface
Definition at line 15 of file pqNonOrthogonalAutoStartImplementation.h.
◆ pqNonOrthogonalAutoStartImplementation()
pqNonOrthogonalAutoStartImplementation::pqNonOrthogonalAutoStartImplementation ( QObject *  p = nullptr)
◆ ~pqNonOrthogonalAutoStartImplementation()
pqNonOrthogonalAutoStartImplementation::~pqNonOrthogonalAutoStartImplementation ( )
override
◆ startup()
void pqNonOrthogonalAutoStartImplementation::startup ( )
If ParaView is already running when the plugin is loaded, this method will be called when the plugin is loaded.
Implements pqAutoStartInterface.
◆ shutdown()
void pqNonOrthogonalAutoStartImplementation::shutdown ( )
◆ UserImplementation
pqNonOrthogonalAutoStart* pqNonOrthogonalAutoStartImplementation::UserImplementation
Definition at line 30 of file pqNonOrthogonalAutoStartImplementation.h.
