pqProgressManager is progress manager. More...
#include <pqProgressManager.h>
Inherits QObject.
Public Slots | |
| void | setProgress (const QString &message, int progress, bool processEvents=false) |
| Update progress. More... | |
| void | setEnableProgress (bool) |
| Enables progress. More... | |
| void | beginProgress () |
| Convenience slots that simply call setEnableProgress(). More... | |
| void | endProgress () |
| void | setEnableAbort (bool) |
| Enables abort. More... | |
| void | triggerAbort () |
| This is called when the user clicks on the "Abort" button. More... | |
| bool | unblockEvents (bool val) |
While progress is enabled, pqProgressManager blocks key/mouse events, except for objects added using addNonBlockableObject. More... | |
Signals | |
| void | progress (const QString &message, int progress) |
| void | enableProgress (bool) |
| void | enableAbort (bool) |
| void | progressStartEvent () |
| void | progressEndEvent () |
| pqProgressManager (QObject *parent=nullptr) | |
| ~pqProgressManager () override | |
| void | lockProgress (QObject *object) |
Locks progress to respond to progress signals set by the object alone. More... | |
| void | unlockProgress (QObject *object) |
| Releases the progress lock. More... | |
| bool | isLocked () const |
| Returns if the progress is currently locked by any object. More... | |
| void | addNonBlockableObject (QObject *o) |
| When progress is enabled, the manager eats all mouse and key events fired except for those objects which are in the non-blockable list. More... | |
| void | removeNonBlockableObject (QObject *o) |
| const QList< QPointer< QObject > > & | nonBlockableObjects () const |
| Returns the list of non-blockable objects. More... | |
Protected Slots | |
| void | onStartProgress () |
| callbacks for signals fired from vtkProcessModule. More... | |
| void | onEndProgress () |
| void | onProgress (vtkObject *) |
| void | onServerAdded (pqServer *) |
| bool | eventFilter (QObject *obj, QEvent *event) override |
| Filter QApplication events. More... | |
Protected Attributes | |
| QPointer< QObject > | Lock |
| QList< QPointer< QObject > > | NonBlockableObjects |
| int | ProgressCount |
| bool | InUpdate |
| bool | EnableProgress |
| bool | ReadyEnableProgress |
| bool | UnblockEvents |
It centralizes progress raising/ handling. Provides ability for any object to lock progress so that only progress fired by itself will be notified to the rest of the world. Also, when progress is enabled, it disables handling of mouse/key events except on those objects in the NonBlockableObjects list.
Definition at line 21 of file pqProgressManager.h.
| pqProgressManager::pqProgressManager | ( | QObject * | parent = nullptr | ) |
| void pqProgressManager::lockProgress | ( | QObject * | object | ) |
All signals sent by other objects are ignored until Unlock is called.
| void pqProgressManager::unlockProgress | ( | QObject * | object | ) |
| bool pqProgressManager::isLocked | ( | ) | const |
This is the API to add/remove non-blockable objects.
Definition at line 49 of file pqProgressManager.h.
Definition at line 50 of file pqProgressManager.h.
Definition at line 55 of file pqProgressManager.h.
slot |
Update progress.
The progress must be enbled by calling enableProgress(true) before calling this method for the progress to be updated.
slot |
Enables progress.
inlineslot |
Definition at line 79 of file pqProgressManager.h.
inlineslot |
Definition at line 80 of file pqProgressManager.h.
slot |
Enables abort.
slot |
It is used to abort the current operation on a vtkAlgorithm object.
slot |
Sometimes it's not possible to add objects explicitly and we may want to temporarily skip blocking of events. This methods can be used for that e.g.
signal |
signal |
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
Definition at line 131 of file pqProgressManager.h.
Definition at line 132 of file pqProgressManager.h.
Definition at line 133 of file pqProgressManager.h.
Definition at line 134 of file pqProgressManager.h.
Definition at line 136 of file pqProgressManager.h.
Definition at line 137 of file pqProgressManager.h.
Definition at line 138 of file pqProgressManager.h.
1.8.13 on Sun Dec 14 2025
