widget to show progress in a QStatusBar. More...
#include <pqProgressWidget.h>
Inherits QWidget.
Public Slots | |
| void | setProgress (const QString &message, int value) |
| Set the progress. More... | |
| void | enableProgress (bool enabled) |
| Enabled/disable the progress. More... | |
| void | enableAbort (bool enabled) |
| Enable/disable the abort button. More... | |
Signals | |
| void | abortPressed () |
| triggered with the abort button is pressed. More... | |
| pqProgressWidget (QWidget *parent=nullptr) | |
| ~pqProgressWidget () override | |
| QToolButton * | getAbortButton () const |
| QToolButton * | abortButton () const |
| Provides access to the abort button. More... | |
| void | setReadyText (const QString &) |
| Set the text to use by default when the progress bar is not enabled which typically corresponds to application not being busy. More... | |
| const QString & | readyText () const |
| void | setBusyText (const QString &) |
| Set the text to use by default when the progress bar is enabled which typically corresponds to application being busy. More... | |
| const QString & | busyText () const |
| void | updateUI () |
| request Qt to paint the widgets. More... | |
| void | enterEvent (QEnterEvent *e) override |
| Overriden to change the application cursor to a "ArrowCursor" when the progress bar is showing progress and the mouse enters the progress widget. More... | |
| void | leaveEvent (QEvent *e) override |
| Overriden to restore the cursor to the default cursor when the mouse leaves the progress widget. More... | |
Protected Attributes | |
| pqProgressWidgetLabel * | ProgressBar |
| QToolButton * | AbortButton |
Properties | |
| QString | readyText |
| QString | busyText |
pqProgressWidget is a widget designed to be used in the QStatusBar of the application to show progress for time consuming tasks in the application.
pqProgressWidget is a replacement for QProgressBar. It has the following differences with QProgressBar.
Definition at line 32 of file pqProgressWidget.h.
| pqProgressWidget::pqProgressWidget | ( | QWidget * | parent = nullptr | ) |
Use abortButton instead.
Definition at line 45 of file pqProgressWidget.h.
Definition at line 50 of file pqProgressWidget.h.
| void pqProgressWidget::setReadyText | ( | const QString & | ) |
Default value is empty.
Definition at line 59 of file pqProgressWidget.h.
| void pqProgressWidget::setBusyText | ( | const QString & | ) |
Default value is "Busy".
Definition at line 69 of file pqProgressWidget.h.
Set the progress.
Progress must be enabled by calling 'enableProgress` otherwise this method will have no effect.
slot |
This is different from enabling/disabling the widget itself. This shows/hides the progress part of the widget.
slot |
signal |
This makes it intuitive for the user to know that they can clik on the abort button to stop the progress.
Definition at line 98 of file pqProgressWidget.h.
Definition at line 99 of file pqProgressWidget.h.
readwrite |
Definition at line 36 of file pqProgressWidget.h.
readwrite |
Definition at line 37 of file pqProgressWidget.h.
1.8.13 on Sun Dec 14 2025
