pqProxyWidgetItem represents a single widget for a property/properties. More...
#include <pqProxyWidgetItem.h>
Inherits QObject.
| ~pqProxyWidgetItem () override | |
| pqPropertyWidget * | propertyWidget () const |
| Return the underlying pqPropertyWidget. More... | |
| void | appendToDefaultVisibilityForRepresentations (const QString &repr) |
| Add representation to the list of representations that forces visibility to be "default", bypassing the "Advanced" option. More... | |
| bool | canShowWidget (bool show_advanced, const QString &filterText, vtkSMProxy *proxy) const |
| Return true if the widget should be shown in the current configuration: advanced mode, filtering text and optional decorators. More... | |
| bool | enableWidget () const |
| Return true if the widget should be enabled. More... | |
| bool | isAdvanced (vtkSMProxy *proxy) const |
| Return true if the property is advanced. More... | |
| void | show (const pqProxyWidgetItem *prevVisibleItem, bool enabled=true, bool show_advanced=false) const |
| Show the underlying widgets Separators are shown only when needed (i.e. More... | |
| void | hide () const |
| Hide the underlying widgets. More... | |
| void | appendToLayout (QGridLayout *glayout, bool singleColumn) |
| Adds widgets to the layout. More... | |
| void | apply () const |
| Utility methods forwarded to the Property widget. More... | |
| void | reset () const |
| void | select () const |
| void | deselect () const |
| static pqProxyWidgetItem * | newItem (pqPropertyWidget *widget, const QString &label, bool advanced, bool informationOnly, const QStringList &searchTags, pqProxyWidget *parentObj) |
| Create a simple pqProxyWidgetItem. More... | |
| static pqProxyWidgetItem * | newGroupItem (pqPropertyWidget *widget, const QString &label, bool showSeparators, bool advanced, const QStringList &searchTags, pqProxyWidget *parentObj) |
| Creates a new item for a property group. More... | |
| static pqProxyWidgetItem * | newMultiItemGroupItem (const QString &group_label, pqPropertyWidget *widget, const QString &widget_label, bool showSeparators, bool advanced, bool informationOnly, const QStringList &searchTags, pqProxyWidget *parentObj) |
| Creates a new item for a property group with several widgets (for individual properties in the group). More... | |
| static QFrame * | newHLine (QWidget *parent) |
| Create a simple horizontal line. More... | |
| static QWidget * | newGroupSeparator (QWidget *parent) |
| Create a separator for a new Group widget. More... | |
While pqProxyWidgetItem mainly handles a pqPropertyWidget with its label, it is also used for propertyGroups.
It can be added to a QGridLayout (see appendToLayout()), so underlying QWidgets are consistently added.
Definition at line 23 of file pqProxyWidgetItem.h.
Use this overload when creating an item for a group where there's a single widget for all the properties in that group.
Useful to add a visible but light separation.
This is mainly more spacing and an horizontal line.
| pqPropertyWidget* pqProxyWidgetItem::propertyWidget | ( | ) | const |
| void pqProxyWidgetItem::appendToDefaultVisibilityForRepresentations | ( | const QString & | repr | ) |
| void pqProxyWidgetItem::apply | ( | ) | const |
| void pqProxyWidgetItem::reset | ( | ) | const |
| void pqProxyWidgetItem::select | ( | ) | const |
| void pqProxyWidgetItem::deselect | ( | ) | const |
| bool pqProxyWidgetItem::canShowWidget | ( | bool | show_advanced, |
| const QString & | filterText, | ||
| vtkSMProxy * | proxy | ||
| ) | const |
| bool pqProxyWidgetItem::enableWidget | ( | ) | const |
Return false if the property is Information only or if at least one decorator say so.
| bool pqProxyWidgetItem::isAdvanced | ( | vtkSMProxy * | proxy | ) | const |
| void pqProxyWidgetItem::show | ( | const pqProxyWidgetItem * | prevVisibleItem, |
| bool | enabled = true, |
| bool | show_advanced = false |
| ) | const |
if another item is around).
| void pqProxyWidgetItem::hide | ( | ) | const |
| void pqProxyWidgetItem::appendToLayout | ( | QGridLayout * | glayout, |
| bool | singleColumn | ||
This is a little greedy. It adds everything that could be potentially shown to the layout. We control visibilities of things like headers and footers dynamically in show()/hide().
1.8.13 on Wed Dec 17 2025
