pqServerResource encapsulates a resource in ParaView. More...
#include <pqServerResource.h>
| pqServerResource () | |
| ~pqServerResource () | |
| pqServerResource & | operator= (const pqServerResource &) |
| pqServerResource (const QString &uri) | |
| Create an pqServerResource from a provided URI. More... | |
| pqServerResource (const QString &uri, const pqServerConfiguration &config) | |
| Create an pqServerResource from a provided URI and store related configuration If the configuration is named, the configuration name will be used as a serverName. More... | |
| pqServerResource (const pqServerResource &) | |
| Create a pqServerResource by copy. More... | |
| const pqServerConfiguration & | configuration () const |
| Returns the pqServerConfiguration from which this resource was created, if any. More... | |
| QString | toURI () const |
| Returns a compact string representation of the complete resource in URI format, see above. More... | |
| QString | serializeString () const |
| Returns a compact string representation of the resource including extra data. More... | |
| QString | scheme () const |
| Returns the resource scheme, builtin, cs, csrc, cdsrs or cdsrsrc. More... | |
| void | setScheme (const QString &) |
| Sets the resource scheme. More... | |
| bool | isReverse () const |
| Returns if the connection scheme is a reverse one. More... | |
| QString | host () const |
| Returns the resource host, or empty string for builtin, cdsrs, and cdsrsrc schemes. More... | |
| void | setHost (const QString &) |
| Sets the resource host. More... | |
| int | port () const |
| Return the resource port, or -1 for builtin, cdsrs, and cdsrsrc schemes. More... | |
| int | port (int default_port) const |
| Return the resource port, or default_port for builtin, cdsrs, and cdsrsrc schemes. More... | |
| void | setPort (int) |
| Set the resource port. More... | |
| QString | dataServerHost () const |
| Return the data server host, if any. More... | |
| void | setDataServerHost (const QString &) |
| Set the data server host. More... | |
| int | dataServerPort () const |
| Return the data server port, if any, or -1. More... | |
| int | dataServerPort (int default_port) const |
| Return the data server port, if any, or default_port. More... | |
| void | setDataServerPort (int) |
| Set the data server port. More... | |
| QString | renderServerHost () const |
| Return the render server host, if any. More... | |
| void | setRenderServerHost (const QString &) |
| Set the render server host. More... | |
| int | renderServerPort () const |
| Return the render server port, if any, or -1. More... | |
| int | renderServerPort (int default_port) const |
| Return the render server port, if any, or default_port. More... | |
| void | setRenderServerPort (int) |
| Set the render server port. More... | |
| QString | path () const |
| Return the path to the resource, if any. More... | |
| void | setPath (const QString &) |
| Set the path to the resource. More... | |
| QString | serverName () const |
| Return the server name of the resource, if any. More... | |
| void | setServerName (const QString &name) |
| Set the server name of the resource. More... | |
| void | addData (const QString &key, const QString &value) |
| Add a data on this resource, with a key/value logic. More... | |
| QString | data (const QString &key) const |
| Get data from this resource, associated with the provided key, if any. More... | |
| QString | data (const QString &key, const QString &default_value) const |
| bool | hasData (const QString &key) const |
| Return true if this resource has data associated with the provided key, false otherwise. More... | |
| pqServerResource | schemeHostsPorts () const |
| Returns a copy of this resource containing only server connection information - scheme, host, and port numbers. More... | |
| pqServerResource | schemeHosts () const |
| Returns a copy of this resource containing a subset of server information - scheme and host (no port numbers) More... | |
| pqServerResource | hostPath () const |
| Returns a copy of this resource containing only host and path information - scheme and port numbers are excluded. More... | |
| pqServerResource | pathServerName () const |
| Returns a copy of this resource containing only path and server name information - scheme, host and port numbers are excluded. More... | |
| bool | operator== (const pqServerResource &) const |
| Operators comparing all elements of the resource. More... | |
| bool | operator!= (const pqServerResource &) const |
| bool | operator< (const pqServerResource &) const |
A resource can be anything, a data file, a list of data files, a state file, or a connection to a server. The resource specification is based on URL-like syntax:
* <scheme>://<scheme-specific-parameters> *
To specify a data or state file, the following syntax is used:
* <connection-scheme>:[//<server-details>]/<path-to-data-file>[#serverName]:KEY:1 *
connection-scheme can be
builtin - for builtin connections cs - for client-server connections (pvserver) csrc - for client-server connections with reverse-connect (pvserver rc) cdsrs - for client-data-server-render-server connections (pvdataserver, pvrenderserver) cdsrsrc - for cdsrs with reverse-connect.server-details are of the form <serverhost-name>:<port> or <dataserver-hostname>:<dataserver-port>/<renderserver-hostname>:<render-server-port> as applicable. Port numbers are always optional.
The KEY should be PARAVIEW_DATA for data file and PARAVIEW_STATE for state file.
Examples:
* builtin:/home/user/foo.vtk * cs://amber1:11112/C:\Users\User\foo.vtk * cdsrsrc://amber2:11111/amber3:22222/home/user/foo.vtk#amberDRS *
To specify a server-connection, without pointing to any data file(s), the following syntax may be used:
* <connection-scheme>:[//<server-details>] *
Examples:
* builtin: * cs://amber1:11112 * cdsrsrc://amber2:11111/amber3:22222 *
As with data-files, port numbers are always optional in when specifying server-details.
Server name is also optional but will be used if available.
Arbitrary data can be added to a resource. ParaView leverages this mechanism to identify statefiles, to save additional files in a file series when referring to a data file, or details about how to connect to the server when referring to a server-connection.
Definition at line 71 of file pqServerResource.h.
| pqServerResource::pqServerResource | ( | ) |
| pqServerResource::~pqServerResource | ( | ) |
| pqServerResource::pqServerResource | ( | const QString & | uri | ) |
| pqServerResource::pqServerResource | ( | const QString & | uri, |
| const pqServerConfiguration & | config | ||
| pqServerResource::pqServerResource | ( | const pqServerResource & | ) |
| pqServerResource& pqServerResource::operator= | ( | const pqServerResource & | ) |
| const pqServerConfiguration& pqServerResource::configuration | ( | ) | const |
| QString pqServerResource::toURI | ( | ) | const |
| QString pqServerResource::serializeString | ( | ) | const |
| QString pqServerResource::scheme | ( | ) | const |
| void pqServerResource::setScheme | ( | const QString & | ) |
| bool pqServerResource::isReverse | ( | ) | const |
| QString pqServerResource::host | ( | ) | const |
| void pqServerResource::setHost | ( | const QString & | ) |
| int pqServerResource::port | ( | ) | const |
| void pqServerResource::setPort | ( | int | ) |
| QString pqServerResource::dataServerHost | ( | ) | const |
| void pqServerResource::setDataServerHost | ( | const QString & | ) |
| int pqServerResource::dataServerPort | ( | ) | const |
| void pqServerResource::setDataServerPort | ( | int | ) |
| QString pqServerResource::renderServerHost | ( | ) | const |
| void pqServerResource::setRenderServerHost | ( | const QString & | ) |
| int pqServerResource::renderServerPort | ( | ) | const |
| void pqServerResource::setRenderServerPort | ( | int | ) |
| QString pqServerResource::path | ( | ) | const |
| void pqServerResource::setPath | ( | const QString & | ) |
| QString pqServerResource::serverName | ( | ) | const |
| void pqServerResource::setServerName | ( | const QString & | name | ) |
| QString pqServerResource::data | ( | const QString & | key | ) | const |
If not, return default_value.
| bool pqServerResource::hasData | ( | const QString & | key | ) | const |
| pqServerResource pqServerResource::schemeHostsPorts | ( | ) | const |
| pqServerResource pqServerResource::schemeHosts | ( | ) | const |
| pqServerResource pqServerResource::hostPath | ( | ) | const |
| pqServerResource pqServerResource::pathServerName | ( | ) | const |
| bool pqServerResource::operator== | ( | const pqServerResource & | ) | const |
| bool pqServerResource::operator!= | ( | const pqServerResource & | ) | const |
| bool pqServerResource::operator< | ( | const pqServerResource & | ) | const |
1.8.13 on Sun Dec 14 2025
