pqSignalAdaptorKeyFrameType is adaptor for the "Type" property of the vtkSMCompositeKeyFrameProxy. More...
#include <pqSignalAdaptorKeyFrameType.h>
| pqSignalAdaptorKeyFrameType (pqKeyFrameTypeWidget *widget, pqPropertyLinks *links, QLabel *valueLabel=nullptr) | |
| Constructor. More... | |
| ~pqSignalAdaptorKeyFrameType () override | |
| void | setKeyFrameProxy (vtkSMProxy *keyframe) |
keyframe is the proxy for the key frame. More... | |
| vtkSMProxy * | getKeyFrameProxy () const |
Public Member Functions inherited from pqSignalAdaptorComboBox | |
| pqSignalAdaptorComboBox (QComboBox *p) | |
| constructor requires a QComboBox More... | |
| QString | currentText () const |
| get the current text of a combo box More... | |
| int | currentIndex () const |
| get the current index of a combo box. More... | |
| QVariant | currentData () const |
| get the user data associated with the current index. More... | |
Public Slots inherited from pqSignalAdaptorComboBox | |
| void | setCurrentText (const QString &) |
| set the current text of a combo box (actually sets the index for the text) More... | |
| void | setCurrentIndex (int index) |
| set the current index of a combox box. More... | |
| void | setCurrentData (const QVariant &data) |
| set the current index to the index with user data as the argument. More... | |
Signals inherited from pqSignalAdaptorComboBox | |
| void | currentTextChanged (const QString &) |
| signal text changed in a combo box More... | |
| void | currentIndexChanged (int) |
Properties inherited from pqSignalAdaptorComboBox | |
| QString | currentText |
| int | currentIndex |
| QVariant | currentData |
For certain types of keyframes, we have additional properties that must be exposed in the GUI, this class manages that. Use this to connect a QComboBox with type listing to the Type property on the proxy.
Definition at line 23 of file pqSignalAdaptorKeyFrameType.h.
| pqSignalAdaptorKeyFrameType::pqSignalAdaptorKeyFrameType | ( | pqKeyFrameTypeWidget * | widget, |
| pqPropertyLinks * | links, | ||
| QLabel * | valueLabel = nullptr |
Constructor.
combo is the combo-box that chooses the type, while frame is the frame in which this adaptor can put additional widgets, if needed. valueLabel is the label that is used for the keyframe value, since based on the type the value label may change. Note that this class will toggle the visibility of this frame as needed.
| void pqSignalAdaptorKeyFrameType::setKeyFrameProxy | ( | vtkSMProxy * | keyframe | ) |
It typically is a vtkSMCompositeKeyFrameProxy or subclass. This is needed to setup the links with the other properties.
| vtkSMProxy* pqSignalAdaptorKeyFrameType::getKeyFrameProxy | ( | ) | const |
1.8.13 on Sun Dec 14 2025
