Signals | Public Member Functions | List of all members
pqTimelineModel Class Reference
pqTimelineModel is a standard item model for ParaView timelines, intended to be used with pqTimelineView, and mainly through pqTimelineWidget. More...
#include <pqTimelineModel.h>
Inherits QStandardItemModel.
Signals
void sourceStateChanged ()
void animationStateChanged ()
 pqTimelineModel (QObject *parent=nullptr)
 ~pqTimelineModel () override
QList< QStandardItem * > createRow (pqTimelineTrack::TrackType type, const QString &name, QMap< int, QVariant > additionalData={})
 Create items under appropriate parent, and set some data on it. More...
void clearRows (pqTimelineTrack::TrackType type)
 Clear rows of given type. More...
void deleteRow (pqTimelineTrack::TrackType type, const QString &registrationName)
 Remove row under type with given registrationName. More...
bool setData (const QModelIndex &index, const QVariant &value, int role=Qt::DisplayRole) override
 Override to handle checkstate. More...
QList< QList< QStandardItem * > > rows (pqTimelineTrack::TrackType type)
 Returns the row list of given type. More...
QList< QList< QStandardItem * > > uncheckedRows (pqTimelineTrack::TrackType type)
 Returns the unchecked row list of given type. More...
void setRowEnabled (pqTimelineTrack::TrackType type, bool enabled, const QString &name=QString())
 Set/Get enable state of the row. More...
bool isRowEnabled (pqTimelineTrack::TrackType type, const QString &name=QString())
void toggleRow (pqTimelineTrack::TrackType type, const QString &name)
void setRowsEnabled (pqTimelineTrack::TrackType type, bool enabled)
A timeline correspond to any element containing a list of meaningful times, as temporal sources and animation cue (see pqTimelineWidget).
This is a tree-like structure with only two levels. Each model row is known as a "Track", than can be of several type (see pqTimelineTrack enum). SOURCE and ANIMATION tracks are grouped under a parent track, resp. TIME and ANIMATION_HEADER making it easier to have dedicated code path.
One column contains the timeline itself, while others contains associated data such as name and custom widget. See pqTimelineColumn enum.
Definition at line 64 of file pqTimelineModel.h.
◆ pqTimelineModel()
pqTimelineModel::pqTimelineModel ( QObject *  parent = nullptr)
◆ ~pqTimelineModel()
pqTimelineModel::~pqTimelineModel ( )
override
◆ createRow()
QList<QStandardItem*> pqTimelineModel::createRow ( pqTimelineTrack::TrackType  type,
const QString &  name,
QMap< int, QVariant >  additionalData = {}
Parent is computed depending on type: SOURCE goes under TIME, ANIMATION under ANIMATION_HEADER. Themself are under the root.
Parameters
typeis always stored under pqTimelineItemRole::TYPE data role. By default
nameis stored under pqTimelineItemRole::REGISTRATIONNAME but can be overriden by additionalData.
additionalDatais a map of data associated to their role.
◆ clearRows()
void pqTimelineModel::clearRows ( pqTimelineTrack::TrackType  type)
◆ deleteRow()
void pqTimelineModel::deleteRow ( pqTimelineTrack::TrackType  type,
const QString &  registrationName
◆ setData()
bool pqTimelineModel::setData ( const QModelIndex &  index,
const QVariant &  value,
int  role = Qt::DisplayRole
override
◆ setRowEnabled()
void pqTimelineModel::setRowEnabled ( pqTimelineTrack::TrackType  type,
bool  enabled,
const QString &  name = QString()
◆ isRowEnabled()
bool pqTimelineModel::isRowEnabled ( pqTimelineTrack::TrackType  type,
◆ toggleRow()
void pqTimelineModel::toggleRow ( pqTimelineTrack::TrackType  type,
◆ setRowsEnabled()
void pqTimelineModel::setRowsEnabled ( pqTimelineTrack::TrackType  type,
bool  enabled
◆ rows()
QList<QList<QStandardItem*> > pqTimelineModel::rows ( pqTimelineTrack::TrackType  type)
◆ uncheckedRows()
QList<QList<QStandardItem*> > pqTimelineModel::uncheckedRows ( pqTimelineTrack::TrackType  type)
◆ sourceStateChanged
void pqTimelineModel::sourceStateChanged ( )
signal
◆ animationStateChanged
void pqTimelineModel::animationStateChanged ( )
signal
