Public Member Functions | Protected Attributes | List of all members
pqTimelinePainter Class Reference
pqTimelineItemDelegate draws timeline in cells. More...
#include <pqTimelinePainter.h>
Inherits QObject.
 pqTimelinePainter (QObject *parent=nullptr)
 ~pqTimelinePainter () override
void paint (QPainter *painter, const QModelIndex &index, const QStyleOptionViewItem &option)
 Paint the whole timeline for given index. More...
Scene informations
Cache information about scene for display purpose.
This is useful to compute tick position, and to do specific label display for locked start and end end.
void setSceneStartTime (double time)
void setSceneEndTime (double time)
 cache scene end time. More...
void setSceneCurrentTime (double time)
 cache scene current time. More...
double getSceneCurrentTime ()
 get scene cursor time More...
void setSceneLockStart (bool lock)
 cache scene lock start. More...
void setSceneLockEnd (bool lock)
 cache scene lock end More...
void setDisplayTimeRange (double start, double end)
 Set / Get the time range to display. More...
QPair< double, doubledisplayTimeRange ()
Start and End rectangles
Get Start and End labels rectangle.
bool hasStartEndLabels ()
QRect getStartLabelRect ()
 Return first cached rect. More...
QRect getEndLabelRect ()
 Return second cached rect. More...
double positionFromTime (double time, const QStyleOptionViewItem &option)
 Return position of the given time. More...
double positionFromTime (double time)
double indexTimeFromPosition (double pos, const QStyleOptionViewItem &option, const QModelIndex &index)
 Return the time of the corresponding position. More...
double timeFromPosition (double pos, const QStyleOptionViewItem &option)
double timeFromPosition (double pos)
Items infos
Extract information from the item data.
bool isTimeTrack (QStandardItem *item)
bool isAnimationTrack (QStandardItem *item)
 return true if item is an animation track More...
std::vector< doublegetTimes (QStandardItem *item)
 get item times using relevant data role. More...
double getSourceTime (QStandardItem *item)
 get source time using relevant data role. More...
QString getLabel (QStandardItem *item, int index)
 return label for given index More...
Paint methods
Paint the different elements of the track.
Those are mainly called from internal code.
See also
paint
void paintBackground (QPainter *painter, const QStyleOptionViewItem &option, bool alternate)
void paintTimeline (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item, bool paintLabels, const QStyleOptionViewItem &labelsOption)
 Paint the whole timeline for given track, i.e. More...
void paintTimeTrack (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item)
 Paint the main timeline, with time labels and a mark for current scene time. More...
void paintSourceTrack (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item)
 a temporal source times. Has a mark for scene time and one for source time. More...
void paintAnimationTrack (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item)
 animation track. One mark per keyframe. More...
void paintSourcePipelineTime (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item)
 time mark for source time More...
void paintSceneCurrentTime (QPainter *painter, const QStyleOptionViewItem &option)
 Paint time mark for scene time. More...
bool paintTick (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item, double time, bool paintLabels, const QStyleOptionViewItem &labelsOption, const QString &label)
 a tick, i.e. More...
void paintTimeMark (QPainter *painter, const QStyleOptionViewItem &option, double pos)
 a time mark, i.e a vertical line at given position. More...
bool paintLabel (QPainter *painter, const QStyleOptionViewItem &option, QStandardItem *item, double time, const QString &label)
 Paint labels as annotation. More...
double SceneCurrentTime = 0
double SceneStartTime = 0
double SceneEndTime = 1
double DisplayStartTime = 0.
double DisplayEndTime = 1.
bool SceneLockStart = false
bool SceneLockEnd = false
A timeline is a list of ticks optionally labeled.
Inner data of QStandardItemModel are used from the following custom roles:
Drawing also depends on the pqTimelineItemRole::TYPE of the current item.
Definition at line 29 of file pqTimelinePainter.h.
◆ pqTimelinePainter()
pqTimelinePainter::pqTimelinePainter ( QObject *  parent = nullptr)
◆ ~pqTimelinePainter()
pqTimelinePainter::~pqTimelinePainter ( )
override
◆ paint()
void pqTimelinePainter::paint ( QPainter *  painter,
const QModelIndex &  index,
const QStyleOptionViewItem &  option
◆ setSceneStartTime()
void pqTimelinePainter::setSceneStartTime ( double  time)
cache scene start time.
◆ setSceneEndTime()
void pqTimelinePainter::setSceneEndTime ( double  time)
◆ setSceneCurrentTime()
void pqTimelinePainter::setSceneCurrentTime ( double  time)
◆ getSceneCurrentTime()
double pqTimelinePainter::getSceneCurrentTime ( )
◆ setSceneLockStart()
void pqTimelinePainter::setSceneLockStart ( bool  lock)
◆ setSceneLockEnd()
void pqTimelinePainter::setSceneLockEnd ( bool  lock)
◆ setDisplayTimeRange()
void pqTimelinePainter::setDisplayTimeRange ( double  start,
double  end
◆ displayTimeRange()
QPair<double, double> pqTimelinePainter::displayTimeRange ( )
◆ hasStartEndLabels()
bool pqTimelinePainter::hasStartEndLabels ( )
Return true if there is at least 2 rects in cache.
◆ getStartLabelRect()
QRect pqTimelinePainter::getStartLabelRect ( )
◆ getEndLabelRect()
QRect pqTimelinePainter::getEndLabelRect ( )
◆ positionFromTime() [1/2]
double pqTimelinePainter::positionFromTime ( double  time,
Return -1 if outside the painting area, i.e. if time is not inside [DisplayStartTime, DisplayEndTime].
◆ positionFromTime() [2/2]
double pqTimelinePainter::positionFromTime ( double  time)
◆ indexTimeFromPosition()
double pqTimelinePainter::indexTimeFromPosition ( double  pos,
const QStyleOptionViewItem &  option,
If given index has stored times, return the nearest one.
◆ timeFromPosition() [1/2]
double pqTimelinePainter::timeFromPosition ( double  pos,
◆ timeFromPosition() [2/2]
double pqTimelinePainter::timeFromPosition ( double  pos)
◆ isTimeTrack()
bool pqTimelinePainter::isTimeTrack ( QStandardItem *  item)
return true if item is the main time track
◆ isAnimationTrack()
bool pqTimelinePainter::isAnimationTrack ( QStandardItem *  item)
◆ getTimes()
std::vector<double> pqTimelinePainter::getTimes ( QStandardItem *  item)
◆ getSourceTime()
double pqTimelinePainter::getSourceTime ( QStandardItem *  item)
◆ getLabel()
QString pqTimelinePainter::getLabel ( QStandardItem *  item,
int  index
◆ paintBackground()
void pqTimelinePainter::paintBackground ( QPainter *  painter,
bool  alternate
paint background
◆ paintTimeline()
void pqTimelinePainter::paintTimeline ( QPainter *  painter,
bool  paintLabels,
const QStyleOptionViewItem &  labelsOption
loop over times to draw ticks and optionnal labels. Special code path to ensure Start and End visibility and position.
◆ paintTimeTrack()
void pqTimelinePainter::paintTimeTrack ( QPainter *  painter,
◆ paintSourceTrack()
void pqTimelinePainter::paintSourceTrack ( QPainter *  painter,
◆ paintAnimationTrack()
void pqTimelinePainter::paintAnimationTrack ( QPainter *  painter,
◆ paintSourcePipelineTime()
void pqTimelinePainter::paintSourcePipelineTime ( QPainter *  painter,
◆ paintSceneCurrentTime()
void pqTimelinePainter::paintSceneCurrentTime ( QPainter *  painter,
◆ paintTick()
bool pqTimelinePainter::paintTick ( QPainter *  painter,
double  time,
bool  paintLabels,
const QStyleOptionViewItem &  labelsOption,
const QString &  label
a tick, i.e.
a mark corresponding to given time. Optionnally paint the associated label. When painting labels, the non-labeled ticks are half-sized, for readability. Return true if the label was painted.
◆ paintTimeMark()
void pqTimelinePainter::paintTimeMark ( QPainter *  painter,
double  pos
◆ paintLabel()
bool pqTimelinePainter::paintLabel ( QPainter *  painter,
double  time,
Return true if the annotation is effectively painted. Do not add label that collides on previously added labels.
◆ SceneCurrentTime
double pqTimelinePainter::SceneCurrentTime = 0
Definition at line 158 of file pqTimelinePainter.h.
◆ SceneStartTime
double pqTimelinePainter::SceneStartTime = 0
Definition at line 159 of file pqTimelinePainter.h.
◆ SceneEndTime
double pqTimelinePainter::SceneEndTime = 1
Definition at line 160 of file pqTimelinePainter.h.
◆ DisplayStartTime
double pqTimelinePainter::DisplayStartTime = 0.
Definition at line 162 of file pqTimelinePainter.h.
◆ DisplayEndTime
double pqTimelinePainter::DisplayEndTime = 1.
Definition at line 163 of file pqTimelinePainter.h.
◆ SceneLockStart
bool pqTimelinePainter::SceneLockStart = false
Definition at line 165 of file pqTimelinePainter.h.
◆ SceneLockEnd
bool pqTimelinePainter::SceneLockEnd = false
Definition at line 166 of file pqTimelinePainter.h.
