virtual bool | GetIgnoreIsolatedChanges () |
| Get/Set if all modifications triggered when not within a Begin/End block should be added to the undo stack or not. More...
virtual void | SetIgnoreIsolatedChanges (bool) |
void | SetUndoStack (vtkSMUndoStack *) override |
| Overridden to add observers to not record changes when the stack is being undone/redone. More...
void | OnStateChange (vtkSMSession *session, vtkTypeUInt32 globalId, const vtkSMMessage *previousState, const vtkSMMessage *newState) override |
| Overridden to filter unwanted event and manage auto undoset creation. More...
virtual void | Begin (const char *label) |
| Begins monitoring of the vtkSMProxyManager for undoable operations. More...
virtual void | End () |
| Stops monitoring of the vtkSMProxyManager for undoable operations. More...
virtual void | PushToStack () |
| If any undoable changes were recorded by the builder, this will push the vtkUndoSet formed on to the UndoStack. More...
virtual void | Clear () |
| Discard all recorded changes that haven't been pushed on the UndoStack. More...
virtual bool | Add (vtkUndoElement *element) |
| One can add arbitrary elements to the active undo set. More...
virtual void | OnCreateObject (vtkSMSession *session, vtkSMMessage *newState) |
void | EndAndPushToStack () |
| Convenience method call End(); PushToStack(); in that order. More...
virtual vtkSMUndoStack * | GetUndoStack () |
| Get/Set the undo stack that this builder will build. More...
virtual void | SetIgnoreAllChanges (bool) |
| If IgnoreAllChanges is true, any server manager changes will be ignored even if the changes happened within a Begin()-End() call. More...
virtual bool | GetIgnoreAllChanges () |
virtual void | Modified () |
