Public Member Functions | Protected Member Functions | List of all members
pqVectorWidgetImpl< T, S > Class Template Reference
pqVectorWidgetImpl is a templated class inherited from pqVectorWidget to be used with QVector classes or QQuaternion. More...
#include <pqVectorWidget.h>
Inheritance diagram for pqVectorWidgetImpl< T, S >:
Collaboration diagram for pqVectorWidgetImpl< T, S >:
 pqVectorWidgetImpl (const T &value, QWidget *parent=nullptr)
value () const
void setValue (int index, float value) override
 Set the value at index index of the QVariant with value. More...
- Public Member Functions inherited from pqVectorWidget
 pqVectorWidget (const QVariant &value, QWidget *parent=nullptr)
 ~pqVectorWidget () override=default
const QVariant & value () const
 Get the value directly in vector form. More...
float getValue (int index) override
- Protected Member Functions inherited from pqVectorWidget
void CreateUI (unsigned int nbElem)
 This function creates an horizontal layout with nbElem spinboxes. More...
- Public Slots inherited from pqVectorWidget
- Signals inherited from pqVectorWidget
void valueChanged (const QVariant &)
 Signal emitted when any component value changed. More...
- Protected Attributes inherited from pqVectorWidget
QVariant Vector
- Properties inherited from pqVectorWidget
QVariant value
template<class T, unsigned int S>
class pqVectorWidgetImpl< T, S >
Definition at line 64 of file pqVectorWidget.h.
◆ pqVectorWidgetImpl()
template<class T , unsigned int S>
pqVectorWidgetImpl< T, S >::pqVectorWidgetImpl ( const T &  value,
QWidget *  parent = nullptr
inline
Definition at line 67 of file pqVectorWidget.h.
◆ value()
T pqVectorWidgetImpl< T, S >::value ( ) const
inline
Definition at line 74 of file pqVectorWidget.h.
◆ setValue()
void pqVectorWidgetImpl< T, S >::setValue ( int  index,
float  value
inlineoverridevirtual
Must be overidden to cast to the specialized QVariant.
Implements pqVectorWidget.
Definition at line 76 of file pqVectorWidget.h.
◆ getValue()
float pqVectorWidgetImpl< T, S >::getValue ( int  index)
inlineoverrideprotectedvirtual
Definition at line 85 of file pqVectorWidget.h.
