implements a coverage based priority queue for vtkOverlappingAMR dataset. More...
#include <vtkAMRStreamingPriorityQueue.h>
void | Initialize (vtkAMRInformation *amr) |
Initializes the queue. More... | |
void | Reinitialize () |
Re-initializes the priority queue using the amr structure given to the most recent call to Initialize(). More... | |
bool | IsEmpty () |
Returns if the queue is empty. More... | |
unsigned int | Pop () |
Pops and returns of composite id for the block at the top of the queue. More... | |
void | SetController (vtkMultiProcessController *) |
If the controller is specified, the queue can be used in parallel. More... | |
virtual vtkMultiProcessController * | GetController () |
void | Update (const double view_planes[24], const double clamp_bounds[6]) |
Updates the priorities of blocks based on the new view frustum planes. More... | |
void | Update (const double view_planes[24]) |
virtual void | Modified () |
static vtkAMRStreamingPriorityQueue * | New () |
static vtkAMRStreamingPriorityQueue * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkAMRStreamingPriorityQueue () | |
~vtkAMRStreamingPriorityQueue () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkMultiProcessController * | Controller |
bool | Debug |
vtkTimeStamp | MTime |
vtkAMRStreamingPriorityQueue is used by representations supporting streaming of AMR datasets to determine the priorities for blocks in the dataset. This class relies on the bounds information provided by the AMR meta-data i.e. vtkAMRInformation. This class support view-based priority computation. Simply provide the view planes (returned by vtkCamera::GetFrustumPlanes()) to the vtkAMRStreamingPriorityQueue::Update() call to update the prorities for the blocks currently in the queue.
Definition at line 28 of file vtkAMRStreamingPriorityQueue.h.
Definition at line 32 of file vtkAMRStreamingPriorityQueue.h.
void vtkAMRStreamingPriorityQueue::SetController | ( | vtkMultiProcessController * | ) |
So long as Initialize(), Update() and Pop() methods are called on all processes (need not be synchronized) and all process get the same amr tree and view_planes (which is generally true with ParaView), the blocks are distributed among the processes. By default, this is set to the vtkMultiProcessController::GetGlobalController();
void vtkAMRStreamingPriorityQueue::Initialize | ( | vtkAMRInformation * | amr | ) |
All information about items in the is lost.
void vtkAMRStreamingPriorityQueue::Reinitialize | ( | ) |
void vtkAMRStreamingPriorityQueue::Update | ( | const double | view_planes[24], |
const double | clamp_bounds[6] | ||
Information about blocks "popped" from the queue is preserved and those blocks are not reinserted in the queue.
bool vtkAMRStreamingPriorityQueue::IsEmpty | ( | ) |
unsigned int vtkAMRStreamingPriorityQueue::Pop | ( | ) |
Test if the queue is empty before calling this method.
Definition at line 85 of file vtkAMRStreamingPriorityQueue.h.
