vtkAxisAlignedCutter Class Reference
Cut data with an Axis-Aligned cut function. More...
#include <vtkAxisAlignedCutter.h>
Inheritance diagram for vtkAxisAlignedCutter:
Collaboration diagram for vtkAxisAlignedCutter:
enum  DesiredOutputPrecision
vtkMTimeType GetMTime () override
 Get the last modified time of this filter. More...
void SetCutFunction (vtkImplicitFunction *function)
 Specify the implicit function to perform the cutting. More...
vtkImplicitFunctionGetCutFunction ()
void SetOffsetValue (int i, double value)
 Set/get a slice offset value at specified index i. More...
double GetOffsetValue (int i)
void SetNumberOfOffsetValues (int number)
 Set/get the number of slice offset values. More...
int GetNumberOfOffsetValues ()
virtual void SetLevelOfResolution (int)
 Sets the level of resolution. More...
virtual int GetLevelOfResolution ()
void SetController (vtkMultiProcessController *controller)
 Get/Set the controller in an MPI environment. More...
vtkMultiProcessControllerGetController ()
vtkDataObjectAlgorithmNewInstance () const
vtkDataObjectGetInput ()
vtkDataObjectGetInput (int port)
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAxisAlignedCutterSafeDownCast (vtkObject *o)
static vtkAxisAlignedCutterNew ()
static vtkDataObjectAlgorithmNew ()
static vtkDataObjectAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkAxisAlignedCutter ()
 ~vtkAxisAlignedCutter () override=default
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int FillInputPortInformation (int, vtkInformation *info) override
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double Progress
char * ProgressText
unsigned long ErrorCode
vtkAxisAlignedCutter is a filter producing Axis-Aligned "slices" of the input data. Among slicing filters, this one allows to preserve the input type. In other words, this filter reduces the dimention of the input by 1, following an implicit cutting function. For example, slicing a 3D vtkHyperTreeGrid will produce one (or several) 2D vtkHyperTreeGrid. For that matter, this filter is limited to Axis-Aligned functions.
Except for vtkOverlapingAMR, this filter can produce multiple slices at once. In such cases, the output slices are stored in a vtkPartitionedDataSetCollection.
In the case of a composite input, this filter will produce a composite output with the same structure, except that each leaf (HyperTreeGrid or PartitionedDataSet containting HTG(s)) will be replaced by a new level of nodes containing slices (one node for each slice). Output will always be a PartitionedDataSetCollection, even if the input is a MultiBlock.
Please note that a composite input is considered valid only if it only contains HTGs or Partitioned DataSets of HTGs. This do not concern Overlaping AMR since they can't be stored in composite datasets.
To recap, currently supported input types are:
Currently supported cutting function is Axis-Aligned vtkPVPlane.
See also
vtkCutter vtkPVCutter vtkPlaneCutter vtkPVPlaneCutter vtkPVMetaSliceDataSet vtkHyperTreeGridAxisCut vtkAMRSliceFilter
Definition at line 57 of file vtkAxisAlignedCutter.h.
Definition at line 60 of file vtkAxisAlignedCutter.h.
◆ vtkAxisAlignedCutter()
vtkAxisAlignedCutter::vtkAxisAlignedCutter ( )
◆ ~vtkAxisAlignedCutter()
vtkAxisAlignedCutter::~vtkAxisAlignedCutter ( )
overrideprotecteddefault
virtual const char* vtkAxisAlignedCutter::GetClassName ( )
static int vtkAxisAlignedCutter::IsTypeOf ( const char *  type)
virtual int vtkAxisAlignedCutter::IsA ( const char *  type)
static vtkAxisAlignedCutter* vtkAxisAlignedCutter::SafeDownCast ( vtkObject o)
void vtkAxisAlignedCutter::PrintSelf ( ostream &  os,
static vtkAxisAlignedCutter* vtkAxisAlignedCutter::New ( )
◆ SetCutFunction()
void vtkAxisAlignedCutter::SetCutFunction ( vtkImplicitFunction function)
For now, only Axis-Aligned planes are supported.
◆ GetCutFunction()
vtkImplicitFunction* vtkAxisAlignedCutter::GetCutFunction ( )
◆ GetMTime()
vtkMTimeType vtkAxisAlignedCutter::GetMTime ( )
This time also depends on the the modified time of the internal CutFunction instance.
◆ SetOffsetValue()
void vtkAxisAlignedCutter::SetOffsetValue ( int  i,
double  value
Negative indices are clamped to 0. New space is allocated if necessary.
◆ GetOffsetValue()
double vtkAxisAlignedCutter::GetOffsetValue ( int  i)
◆ SetNumberOfOffsetValues()
void vtkAxisAlignedCutter::SetNumberOfOffsetValues ( int  number)
Allocate new space to store them if needed.
◆ GetNumberOfOffsetValues()
int vtkAxisAlignedCutter::GetNumberOfOffsetValues ( )
◆ SetLevelOfResolution()
virtual void vtkAxisAlignedCutter::SetLevelOfResolution ( int  )
Default is 0.
Note: Only used for cutting overlapping AMR.
◆ GetLevelOfResolution()
virtual int vtkAxisAlignedCutter::GetLevelOfResolution ( )
Default is 0.
◆ SetController()
void vtkAxisAlignedCutter::SetController ( vtkMultiProcessController controller)
If one sets the controller to nullptr, an instance of vtkDummyController is stored instead. GetController never returns nullptr.
◆ GetController()
vtkMultiProcessController* vtkAxisAlignedCutter::GetController ( )
◆ RequestDataObject()
int vtkAxisAlignedCutter::RequestDataObject ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestData()
int vtkAxisAlignedCutter::RequestData ( vtkInformation ,
◆ FillInputPortInformation()
int vtkAxisAlignedCutter::FillInputPortInformation ( int  ,
vtkInformation info
