vtkBalancedRedistributePolyData Class Reference
do balance of cells on processors More...
#include <vtkBalancedRedistributePolyData.h>
Inheritance diagram for vtkBalancedRedistributePolyData:
Collaboration diagram for vtkBalancedRedistributePolyData:
typedef vtkWeightedRedistributePolyData Superclass
- Public Types inherited from vtkWeightedRedistributePolyData
typedef vtkRedistributePolyData Superclass
- Public Types inherited from vtkRedistributePolyData
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
- Public Member Functions inherited from vtkWeightedRedistributePolyData
void SetWeights (int, int, float)
- Public Member Functions inherited from vtkRedistributePolyData
virtual void SetController (vtkMultiProcessController *)
 The filter needs a controller to determine which process it is in. More...
virtual vtkMultiProcessControllerGetController ()
virtual int GetColorProc ()
virtual void SetColorProc (int)
void SetColorProc ()
virtual void SetSocketController (vtkSocketController *)
 These are here for ParaView compatibility. More...
virtual void SetPassThrough (int)
virtual int GetPassThrough ()
virtual void PassThroughOn ()
virtual void PassThroughOff ()
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithmNewInstance () const
vtkDataObjectGetInput ()
vtkDataObjectGetInput (int port)
vtkPolyDataGetPolyDataInput (int port)
vtkPolyDataGetOutput ()
vtkPolyDataGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkBalancedRedistributePolyDataSafeDownCast (vtkObject *o)
static vtkBalancedRedistributePolyDataNew ()
- Static Public Member Functions inherited from vtkWeightedRedistributePolyData
static vtkWeightedRedistributePolyDataSafeDownCast (vtkObject *o)
static vtkWeightedRedistributePolyDataNew ()
 Construct object. More...
- Static Public Member Functions inherited from vtkRedistributePolyData
static vtkRedistributePolyDataSafeDownCast (vtkObject *o)
static vtkRedistributePolyDataNew ()
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithmNew ()
static vtkPolyDataAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkBalancedRedistributePolyData ()
 ~vtkBalancedRedistributePolyData () override
void MakeSchedule (vtkPolyData *, vtkCommSched *) override
- Protected Member Functions inherited from vtkWeightedRedistributePolyData
 vtkWeightedRedistributePolyData ()
 ~vtkWeightedRedistributePolyData () override
void MakeSchedule (vtkPolyData *input, vtkCommSched *) override
- Protected Member Functions inherited from vtkRedistributePolyData
 vtkRedistributePolyData ()
 ~vtkRedistributePolyData () override
void OrderSchedule (vtkCommSched *)
void SendCellSizes (vtkIdType *, vtkIdType *, vtkPolyData *, int, vtkIdType &, vtkIdType *, vtkIdType **)
void CopyCells (vtkIdType *, vtkPolyData *, vtkPolyData *, vtkIdType **)
void SendCells (vtkIdType *, vtkIdType *, vtkPolyData *, vtkPolyData *, int, vtkIdType &, vtkIdType *, vtkIdType **)
void ReceiveCells (vtkIdType *, vtkIdType *, vtkPolyData *, int, vtkIdType *, vtkIdType *, vtkIdType, vtkIdType)
void FindMemReq (vtkIdType *, vtkPolyData *, vtkIdType &, vtkIdType *)
void AllocateCellDataArrays (vtkDataSetAttributes *, vtkIdType **, int, vtkIdType *)
void AllocatePointDataArrays (vtkDataSetAttributes *, vtkIdType *, int, vtkIdType)
void AllocateArrays (vtkDataArray *, vtkIdType)
void CopyDataArrays (vtkDataSetAttributes *, vtkDataSetAttributes *, vtkIdType, vtkIdType *, int)
void CopyCellBlockDataArrays (vtkDataSetAttributes *, vtkDataSetAttributes *, vtkIdType, vtkIdType, vtkIdType, vtkIdType, int)
void CopyArrays (vtkDataArray *, vtkDataArray *, vtkIdType, vtkIdType *, int)
void CopyBlockArrays (vtkDataArray *, vtkDataArray *, vtkIdType, vtkIdType, vtkIdType, vtkIdType, int)
void SendDataArrays (vtkDataSetAttributes *, vtkDataSetAttributes *, vtkIdType, int, vtkIdType *, int)
void SendCellBlockDataArrays (vtkDataSetAttributes *, vtkDataSetAttributes *, vtkIdType, int, vtkIdType, int)
void SendArrays (vtkDataArray *, vtkIdType, int, vtkIdType *, int)
void SendBlockArrays (vtkDataArray *, vtkIdType, int, vtkIdType, int)
void ReceiveDataArrays (vtkDataSetAttributes *, vtkIdType, int, vtkIdType *, int)
void ReceiveArrays (vtkDataArray *, vtkIdType, int, vtkIdType *, int)
void CompleteInputArrays (vtkPolyData *input)
void ReceiveInputArrays (vtkDataSetAttributes *attr, int recFrom)
void SendInputArrays (vtkDataSetAttributes *attr, int sendTo)
int DoubleCheckArrays (vtkPolyData *input)
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkWeightedRedistributePolyData
enum  {
  NUM_LOC_CELLS_TAG = 70, SCHED_LEN_1_TAG = 300, SCHED_LEN_2_TAG = 301, SCHED_1_TAG = 310,
  SCHED_2_TAG = 311
- Protected Types inherited from vtkRedistributePolyData
enum  {
  CELL_ID_TAG = 10, POINT_COORDS_TAG = 20, NUM_POINTS_TAG = 30, NUM_CELLS_TAG = 40,
  BOUNDS_TAG = 60, CNT_SEND_TAG = 80, CNT_REC_TAG = 90, SEND_PROC_TAG = 100,
  SEND_NUM_TAG = 110, REC_PROC_TAG = 120, REC_NUM_TAG = 130, NUM_CURR_CELLS_TAG = 140,
  CELL_CNT_TAG = 150, CELL_TAG = 160, POINTS_SIZE_TAG = 170, POINTS_TAG = 180
- Protected Attributes inherited from vtkWeightedRedistributePolyData
floatWeights
- Protected Attributes inherited from vtkRedistributePolyData
vtkMultiProcessControllerController
int ColorProc
double Progress
char * ProgressText
unsigned long ErrorCode
Definition at line 18 of file vtkBalancedRedistributePolyData.h.
Definition at line 22 of file vtkBalancedRedistributePolyData.h.
◆ vtkBalancedRedistributePolyData()
vtkBalancedRedistributePolyData::vtkBalancedRedistributePolyData ( )
◆ ~vtkBalancedRedistributePolyData()
vtkBalancedRedistributePolyData::~vtkBalancedRedistributePolyData ( )
virtual const char* vtkBalancedRedistributePolyData::GetClassName ( )
Reimplemented from vtkWeightedRedistributePolyData.
static int vtkBalancedRedistributePolyData::IsTypeOf ( const char *  type)
virtual int vtkBalancedRedistributePolyData::IsA ( const char *  type)
static vtkBalancedRedistributePolyData* vtkBalancedRedistributePolyData::SafeDownCast ( vtkObject o)
void vtkBalancedRedistributePolyData::PrintSelf ( ostream &  os,
Reimplemented from vtkPolyDataAlgorithm.
static vtkBalancedRedistributePolyData* vtkBalancedRedistributePolyData::New ( )
◆ MakeSchedule()
void vtkBalancedRedistributePolyData::MakeSchedule ( vtkPolyData ,
vtkCommSched
overrideprotectedvirtual
Reimplemented from vtkRedistributePolyData.
