vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor, such as C, Fortran. More...
#include <vtkCPAdaptorAPI.h>
| vtkCPAdaptorAPI (const vtkCPAdaptorAPI &)=delete | |
| void | operator= (const vtkCPAdaptorAPI &)=delete |
| static vtkCPAdaptorAPI * | SafeDownCast (vtkObject *o) |
| static void | CoProcessorInitialize () |
| call at the start of the simulation More... | |
| static void | CoProcessorFinalize () |
| call at the end of the simulation More... | |
| static void | RequestDataDescription (int *timeStep, double *time, int *coprocessThisTimeStep) |
| this is the function that determines whether or not there is anything to coprocess this time step More... | |
| static void | NeedToCreateGrid (int *needGrid) |
| this function sets needgrid to 1 if it does not have a copy of the grid it sets needgrid to 0 if it does have a copy of the grid but does not check if the grid is modified or needs to be updated More... | |
| static void | CoProcess () |
| do the actual coprocessing. More... | |
| static vtkCPDataDescription * | GetCoProcessorData () |
| provides access to the vtkCPDataDescription instance. More... | |
| static vtkCPProcessor * | GetCoProcessor () |
| provides access to the vtkCPProcessor instance. More... | |
| vtkCPAdaptorAPI () | |
| ~vtkCPAdaptorAPI () override | |
Static Protected Attributes | |
| static vtkCPDataDescription * | CoProcessorData |
| static vtkCPProcessor * | CoProcessor |
| static bool | IsTimeDataSet |
Definition at line 15 of file vtkCPAdaptorAPI.h.
| typedef vtkObject vtkCPAdaptorAPI::Superclass |
Definition at line 18 of file vtkCPAdaptorAPI.h.
delete |
Reimplemented in vtkCPPythonAdaptorAPI.
it is assumed that the vtkCPDataDescription has been filled in elsewhere.
inlinestatic |
Definition at line 41 of file vtkCPAdaptorAPI.h.
inlinestatic |
Definition at line 44 of file vtkCPAdaptorAPI.h.
delete |
staticprotected |
Definition at line 53 of file vtkCPAdaptorAPI.h.
staticprotected |
Definition at line 54 of file vtkCPAdaptorAPI.h.
staticprotected |
Definition at line 61 of file vtkCPAdaptorAPI.h.
1.8.13 on Sat Dec 13 2025
