vtkCPUnstructuredGridBuilder Class Reference
Class for creating unstructured grids. More...
#include <vtkCPUnstructuredGridBuilder.h>
Inheritance diagram for vtkCPUnstructuredGridBuilder:
Collaboration diagram for vtkCPUnstructuredGridBuilder:
typedef vtkCPGridBuilder Superclass
- Public Types inherited from vtkCPGridBuilder
typedef vtkCPBaseGridBuilder Superclass
- Public Types inherited from vtkCPBaseGridBuilder
vtkDataObjectGetGrid (unsigned long timeStep, double time, int &builtNewGrid) override
 Return a grid. More...
vtkUnstructuredGridGetUnstructuredGrid ()
 Get the UnstructuredGrid. More...
bool SetPoints (vtkPoints *points)
 Set the vtkPoints of the vtkUnstructuredGrid. More...
virtual void Allocate (vtkIdType numCells=1000, int extSize=1000)
 Allocate memory for the cells on UnstructuredGrid. More...
vtkIdType InsertNextCell (int type, vtkIdType npts, vtkIdType *pts)
 Insert/create cell in object by type and list of point ids defining cell topology. More...
vtkIdType InsertNextCell (int type, vtkIdList *ptIds)
- Public Member Functions inherited from vtkCPGridBuilder
void SetFieldBuilder (vtkCPBaseFieldBuilder *fieldBuilder)
 Set/get the FieldBuilder. More...
vtkCPBaseFieldBuilderGetFieldBuilder ()
static vtkCPUnstructuredGridBuilderNew ()
static vtkCPUnstructuredGridBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPGridBuilder
static vtkCPGridBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPBaseGridBuilder
static vtkCPBaseGridBuilderSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPUnstructuredGridBuilder ()
 ~vtkCPUnstructuredGridBuilder () override
void SetUnstructuredGrid (vtkUnstructuredGrid *grid)
 Macro to set UnstructuredGrid. More...
- Protected Member Functions inherited from vtkCPGridBuilder
 vtkCPGridBuilder ()
 ~vtkCPGridBuilder () override
- Protected Member Functions inherited from vtkCPBaseGridBuilder
 vtkCPBaseGridBuilder ()
 ~vtkCPBaseGridBuilder () override
bool IsGridModified
 Flag to indicate if UnstructuredGrid has been modified since last call to GetGrid(). More...
Class for creating vtkUnstructuredGrids for a test driver. Note that the user must call SetPoints(), Allocate(), and InsertNextCell().
Definition at line 22 of file vtkCPUnstructuredGridBuilder.h.
Definition at line 26 of file vtkCPUnstructuredGridBuilder.h.
◆ vtkCPUnstructuredGridBuilder()
vtkCPUnstructuredGridBuilder::vtkCPUnstructuredGridBuilder ( )
◆ ~vtkCPUnstructuredGridBuilder()
vtkCPUnstructuredGridBuilder::~vtkCPUnstructuredGridBuilder ( )
static vtkCPUnstructuredGridBuilder* vtkCPUnstructuredGridBuilder::New ( )
virtual const char* vtkCPUnstructuredGridBuilder::GetClassName ( )
Reimplemented from vtkCPGridBuilder.
static int vtkCPUnstructuredGridBuilder::IsTypeOf ( const char *  type)
virtual int vtkCPUnstructuredGridBuilder::IsA ( const char *  type)
static vtkCPUnstructuredGridBuilder* vtkCPUnstructuredGridBuilder::SafeDownCast ( vtkObject o)
void vtkCPUnstructuredGridBuilder::PrintSelf ( ostream &  os,
◆ GetGrid()
vtkDataObject* vtkCPUnstructuredGridBuilder::GetGrid ( unsigned long  timeStep,
double  time,
int builtNewGrid
Return a grid.
BuiltNewGrid is set to 0 if the grids that were returned were already built before. vtkCPUnstructuredGridBuilder will also delete the grid.
Implements vtkCPGridBuilder.
◆ GetUnstructuredGrid()
vtkUnstructuredGrid* vtkCPUnstructuredGridBuilder::GetUnstructuredGrid ( )
◆ SetPoints()
bool vtkCPUnstructuredGridBuilder::SetPoints ( vtkPoints points)
Returns true if successful.
◆ Allocate()
virtual void vtkCPUnstructuredGridBuilder::Allocate ( vtkIdType  numCells = 1000,
int  extSize = 1000
◆ InsertNextCell() [1/2]
vtkIdType vtkCPUnstructuredGridBuilder::InsertNextCell ( int  type,
vtkIdType  npts,
vtkIdType pts
◆ InsertNextCell() [2/2]
vtkIdList ptIds
◆ SetUnstructuredGrid()
void vtkCPUnstructuredGridBuilder::SetUnstructuredGrid ( vtkUnstructuredGrid grid)
◆ IsGridModified
bool vtkCPUnstructuredGridBuilder::IsGridModified
Definition at line 69 of file vtkCPUnstructuredGridBuilder.h.
