Helper class for Camera Manipulators. More...
#include <vtkCameraManipulatorGUIHelper.h>
| virtual void | UpdateGUI ()=0 |
| Called by the manipulator to update the GUI. More... | |
| virtual int | GetActiveSourceBounds (double bounds[6])=0 |
| Some interactors use the bounds of the active source. More... | |
| virtual int | GetActiveActorTranslate (double translate[3])=0 |
| Called to get/set the translation for the actor for the active source in the active view. More... | |
| virtual int | SetActiveActorTranslate (double translate[3])=0 |
| static vtkCameraManipulatorGUIHelper * | SafeDownCast (vtkObject *o) |
| virtual int | GetCenterOfRotation (double center[3])=0 |
| Get the center of rotation. More... | |
| vtkCameraManipulatorGUIHelper () | |
| ~vtkCameraManipulatorGUIHelper () override | |
This class is the interaface that defines API for a helper class used by some specialized camera manipulators that needed access to GUI. GUI implementations subclass this. vtkPVInteractorStyle sets the helper on every manipulator, if available so that the manipulator can use it.
Definition at line 23 of file vtkCameraManipulatorGUIHelper.h.
Definition at line 26 of file vtkCameraManipulatorGUIHelper.h.
Returns 0 if not applicable.
pure virtual |
This typically involves calling processing pending events on the GUI.
The method returns 0 is no active source is present or not supported by GUI, otherwise returns 1 and the bounds are filled into the passed argument array.
pure virtual |
If applicable returns 1, otherwise returns 0.
pure virtual |
1.8.13 on Sun Dec 14 2025
