combine multiple representations into one with only 1 representation active at a time. More...
#include <vtkCompositeRepresentation.h>
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| void | SetVisibility (bool val) override |
| Methods overridden to propagate to the active representation. More... | |
| vtkPVDataRepresentation * | GetActiveRepresentation () |
| Returns the active representation if valid. More... | |
| void | SetSelectionConnection (vtkAlgorithmOutput *input) |
| Set the selection connection. More... | |
| Propagate the modification to all internal representations. More... | |
| vtkDataObject * | GetRenderedDataObject (int port) override |
| Returns the data object that is rendered from the given input port. More... | |
| vtkStringArray * | GetRepresentationTypes () |
| Returns the list of available representation types as a string array. More... | |
| virtual void | AddRepresentation (const char *key, vtkPVDataRepresentation *repr) |
| Add/Remove representations. More... | |
| virtual void | RemoveRepresentation (vtkPVDataRepresentation *repr) |
| virtual void | RemoveRepresentation (const char *key) |
| void | SetActiveRepresentation (const char *key) |
| Set the active key. More... | |
| const char * | GetActiveRepresentationKey () |
| Overridden to simply pass the input to the internal representations. More... | |
| void | SetInputConnection (vtkAlgorithmOutput *input) override |
| void | AddInputConnection (vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, int idx) override |
| void | SetUpdateTime (double time) override |
| Passed on to internal representations as well. More... | |
| void | SetForceUseCache (bool val) override |
| void | SetForcedCacheKey (double val) override |
Public Member Functions inherited from vtkPVDataRepresentation | |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
vtkCompositeRepresentation makes is possible to combine multiple representations into one. Only one representation can be active at a give time. vtkCompositeRepresentation provides API to add the representations that form the composite and to pick the active representation.
vtkCompositeRepresentation relies on call AddToView and RemoveFromView on the internal representations whenever it needs to change the active representation. So it is essential that representations handle those methods correctly and don't suffer from uncanny side effects when that's done repeatedly.
Definition at line 28 of file vtkCompositeRepresentation.h.
Definition at line 32 of file vtkCompositeRepresentation.h.
Reimplemented in vtkPVCompositeRepresentation, and vtkPVCompositeOrthographicSliceRepresentation.
vtkDataRepresentation::GetVisibility() returns false. Reimplemented from vtkPVDataRepresentation.
key is a unique string used to identify that representation.
| void vtkCompositeRepresentation::SetActiveRepresentation | ( | const char * | key | ) |
Set the active key.
If a valid key is not specified, then none of the representations is treated as active.
| const char* vtkCompositeRepresentation::GetActiveRepresentationKey | ( | ) |
Set the active key.
| vtkPVDataRepresentation* vtkCompositeRepresentation::GetActiveRepresentation | ( | ) |
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
| void vtkCompositeRepresentation::SetSelectionConnection | ( | vtkAlgorithmOutput * | input | ) |
This is used to pass a selection source output to the mapper in order to display the selection content.
Reimplemented in vtkPVCompositeOrthographicSliceRepresentation, and vtkPVCompositeRepresentation.
| vtkStringArray* vtkCompositeRepresentation::GetRepresentationTypes | ( | ) |
Reimplemented in vtkPVCompositeRepresentation.
overrideprotectedvirtual |
Fires UpdateDataEvent.
1.8.13 on Sun Dec 14 2025
