display configuration container More...
#include <vtkDisplayConfiguration.h>
virtual bool | GetShowBorders () |
Get whether to use window borders / frames are to be shown. More... | |
virtual bool | GetFullScreen () |
Returns true of each display should simply be full-screen. More... | |
virtual double | GetEyeSeparation () |
Get eye separation. More... | |
int | GetNumberOfDisplays () const |
Returns the count for display specified. More... | |
bool | LoadPVX (const char *fname) |
Parses a PVX file to load display configuration information. More... | |
const char * | GetEnvironment (int index) const |
Returns information about each display specified. More... | |
vtkTuple< int, 4 > | GetGeometry (int index) const |
vtkTuple< double, 3 > | GetLowerLeft (int index) const |
vtkTuple< double, 3 > | GetLowerRight (int index) const |
vtkTuple< double, 3 > | GetUpperRight (int index) const |
bool | GetHasCorners (int index) const |
bool | GetCoverable (int index) const |
virtual void | Modified () |
static vtkDisplayConfiguration * | New () |
static vtkDisplayConfiguration * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkDisplayConfiguration () | |
~vtkDisplayConfiguration () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkDisplayConfiguration is a container used by vtkRemotingCoreConfiguration to manage display configurations which are needed for CAVE and other immersive displays.
Definition at line 20 of file vtkDisplayConfiguration.h.
Definition at line 24 of file vtkDisplayConfiguration.h.
If so, display geometry is ignored.
Get eye separation.
int vtkDisplayConfiguration::GetNumberOfDisplays | ( | ) | const |
The Coverable
field is only used on X windows systems, and indicates that the window should be manageable by the window manager. This means it can be covered by other windows, and a taskbar item is available to bring it back to the front.
The Coverable
The Coverable
The Coverable
The Coverable
bool vtkDisplayConfiguration::GetHasCorners | ( | int | index | ) | const |
The Coverable
bool vtkDisplayConfiguration::GetCoverable | ( | int | index | ) | const |
The Coverable
bool vtkDisplayConfiguration::LoadPVX | ( | const char * | fname | ) |
