virtual bool | GetNeedsUpdate (double time) |
| Check whether the provided time falls within the algorithm TimeRange, if it does return true to update the source with the new time. More...
void | Modified () override |
| LiveSources algorithm requires calling this->Modified() to update the data. More...
virtual double * | GetTimeRange () |
| Return the first and last time steps of the implemented algorithm. More...
virtual void | GetTimeRange (double &, double &) |
virtual void | GetTimeRange (double [2]) |
vtkTypeBool | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Process a request from the executive. More...
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
| vtkEmulatedTimeAlgorithm () |
| ~vtkEmulatedTimeAlgorithm () override |
virtual int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)=0 |
| This is called within ProcessRequest. More...
virtual int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)=0 |
| This is called within ProcessRequest when a request asks the algorithm to do its work. More...
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| If an update is needed from the LiveSource behavior, update the current pipeline timestep. More...
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
Provide a base API for a emulated real time LiveSource.
This class is intended to be inherited by a temporal algorithm. It allows the algorithm to be updated at regular time intervals, using ParaView LiveSource concept, while also seamlessly functioning with standard vtk animation sequences.
An use case to use this class would be is to replicate the behavior of a LiveSource which has been recorded in a file. It's important to note that time in this context is measured in seconds.
The inherited class should then be defined as a LiveSource in its XML definition, as shown below:
<Hints>
<LiveSource interval="100" emulated_time="1" />
</Hints>
If the pipeline process is taking more time that the timesteps gap, it will skip frames.
- See also
- pqLiveSourceBehavior, pqLiveSourceManager
Definition at line 38 of file vtkEmulatedTimeAlgorithm.h.
