vtkExtractSelectionRange Class Reference
compute the range of the input selection. More...
#include <vtkExtractSelectionRange.h>
Inheritance diagram for vtkExtractSelectionRange:
Collaboration diagram for vtkExtractSelectionRange:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetArrayName (const char *)
 Set the name of the array used to compute the range. More...
virtual char * GetArrayName ()
virtual void SetFieldType (int)
 Set/Get the field type of the selection. More...
virtual int GetFieldType ()
virtual void SetComponent (int)
 Set/Get the component used to compute the range. More...
virtual int GetComponent ()
virtual doubleGetRange ()
 Get the output range. More...
virtual void GetRange (double &, double &)
virtual void GetRange (double [2])
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithmNewInstance () const
vtkTableGetOutput ()
vtkTableGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkExtractSelectionRangeNew ()
static vtkExtractSelectionRangeSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithmNew ()
static vtkTableAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkExtractSelectionRange ()
 ~vtkExtractSelectionRange () override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
int FieldType
int Component
char * ArrayName
double Range [2]
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkExtractSelectionRange is used to compute the range of an input selection. This is an internal filter designed to be used to "compute visible range" for a dataset.
Definition at line 18 of file vtkExtractSelectionRange.h.
Definition at line 22 of file vtkExtractSelectionRange.h.
◆ vtkExtractSelectionRange()
vtkExtractSelectionRange::vtkExtractSelectionRange ( )
◆ ~vtkExtractSelectionRange()
vtkExtractSelectionRange::~vtkExtractSelectionRange ( )
static vtkExtractSelectionRange* vtkExtractSelectionRange::New ( )
virtual const char* vtkExtractSelectionRange::GetClassName ( )
static int vtkExtractSelectionRange::IsTypeOf ( const char *  type)
virtual int vtkExtractSelectionRange::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkExtractSelectionRange* vtkExtractSelectionRange::SafeDownCast ( vtkObject o)
void vtkExtractSelectionRange::PrintSelf ( ostream &  os,
◆ SetArrayName()
virtual void vtkExtractSelectionRange::SetArrayName ( const char *  )
◆ GetArrayName()
virtual char* vtkExtractSelectionRange::GetArrayName ( )
◆ SetFieldType()
virtual void vtkExtractSelectionRange::SetFieldType ( int  )
◆ GetFieldType()
virtual int vtkExtractSelectionRange::GetFieldType ( )
◆ SetComponent()
virtual void vtkExtractSelectionRange::SetComponent ( int  )
◆ GetComponent()
virtual int vtkExtractSelectionRange::GetComponent ( )
◆ GetRange() [1/3]
virtual double* vtkExtractSelectionRange::GetRange ( )
◆ GetRange() [2/3]
virtual void vtkExtractSelectionRange::GetRange ( double ,
double
◆ GetRange() [3/3]
virtual void vtkExtractSelectionRange::GetRange ( double  [2])
◆ FillInputPortInformation()
int vtkExtractSelectionRange::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestData()
int vtkExtractSelectionRange::RequestData ( vtkInformation request,
vtkInformationVector outputVector
◆ FieldType
int vtkExtractSelectionRange::FieldType
Definition at line 64 of file vtkExtractSelectionRange.h.
◆ Component
int vtkExtractSelectionRange::Component
Definition at line 65 of file vtkExtractSelectionRange.h.
◆ ArrayName
char* vtkExtractSelectionRange::ArrayName
Definition at line 66 of file vtkExtractSelectionRange.h.
◆ Range
double vtkExtractSelectionRange::Range[2]
Definition at line 67 of file vtkExtractSelectionRange.h.
