Public Member Functions inherited from vtkLegacyPParticleTracerBase |
virtual void | SetController (vtkMultiProcessController *controller) |
| Set/Get the controller used when sending particles between processes The controller must be an instance of vtkMPIController. More...
virtual vtkMultiProcessController * | GetController () |
Public Member Functions inherited from vtkLegacyParticleTracerBase |
void | PrintParticleHistories () |
void | SetIntegrator (vtkInitialValueProblemSolver *) |
virtual vtkInitialValueProblemSolver * | GetIntegrator () |
void | SetIntegratorType (int type) |
int | GetIntegratorType () |
void | SetInterpolatorType (int interpolatorType) |
| Set the type of the velocity field interpolator to determine whether INTERPOLATOR_WITH_DATASET_POINT_LOCATOR or INTERPOLATOR_WITH_CELL_LOCATOR is employed for locating cells during streamline integration. More...
void | SetInterpolatorTypeToDataSetPointLocator () |
| Set the velocity field interpolator type to one that uses a point locator to perform local spatial searching. More...
void | SetInterpolatorTypeToCellLocator () |
| Set the velocity field interpolator type to one that uses a cell locator to perform spatial searching. More...
virtual bool | GetComputeVorticity () |
| Turn on/off vorticity computation at streamline points (necessary for generating proper stream-ribbons using the vtkRibbonFilter. More...
void | SetComputeVorticity (bool) |
virtual double | GetTerminalSpeed () |
| Specify the terminal speed value, below which integration is terminated. More...
void | SetTerminalSpeed (double) |
virtual double | GetRotationScale () |
| This can be used to scale the rate with which the streamribbons twist. More...
void | SetRotationScale (double) |
virtual void | SetIgnorePipelineTime (vtkTypeBool) |
| To get around problems with the Paraview Animation controls we can just animate the time step and ignore the TIME_ requests. More...
virtual vtkTypeBool | GetIgnorePipelineTime () |
virtual void | IgnorePipelineTimeOn () |
virtual void | IgnorePipelineTimeOff () |
virtual int | GetForceReinjectionEveryNSteps () |
| When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow. More...
void | SetForceReinjectionEveryNSteps (int) |
void | SetTerminationTime (double t) |
| Setting TerminationTime to a positive value will cause particles to terminate when the time is reached. More...
virtual double | GetTerminationTime () |
virtual double | GetStartTime () |
| Set the time value for particle tracing to begin. More...
void | SetStartTime (double t) |
virtual void | SetStaticSeeds (vtkTypeBool) |
| if StaticSeeds is set and the mesh is static, then every time particles are injected we can re-use the same injection information. More...
virtual vtkTypeBool | GetStaticSeeds () |
virtual void | SetMeshOverTime (int meshOverTime) |
virtual int | GetMeshOverTimeMinValue () |
virtual int | GetMeshOverTimeMaxValue () |
void | SetMeshOverTimeToDifferent () |
void | SetMeshOverTimeToStatic () |
void | SetMeshOverTimeToLinearTransformation () |
void | SetMeshOverTimeToSameTopology () |
virtual int | GetMeshOverTime () |
virtual void | SetStaticMesh (vtkTypeBool staticMesh) |
| if StaticMesh is set, many optimizations for cell caching can be assumed. More...
virtual vtkTypeBool | GetStaticMesh () |
virtual void | SetParticleWriter (vtkAbstractParticleWriter *pw) |
| Set/Get the Writer associated with this Particle Tracer Ideally a parallel IO capable vtkH5PartWriter should be used which will collect particles from all parallel processes and write them to a single HDF5 file. More...
virtual vtkAbstractParticleWriter * | GetParticleWriter () |
| vtkSetFilePathMacro (ParticleFileName) |
| Set/Get the filename to be used with the particle writer when dumping particles to disk. More...
| vtkGetFilePathMacro (ParticleFileName) |
virtual void | SetEnableParticleWriting (vtkTypeBool) |
virtual vtkTypeBool | GetEnableParticleWriting () |
virtual void | EnableParticleWritingOn () |
virtual void | EnableParticleWritingOff () |
virtual void | SetDisableResetCache (vtkTypeBool) |
| Set/Get the flag to disable cache This is off by default and turned on in special circumstances such as in a coprocessing workflow. More...
virtual vtkTypeBool | GetDisableResetCache () |
virtual void | DisableResetCacheOn () |
virtual void | DisableResetCacheOff () |
void | AddSourceConnection (vtkAlgorithmOutput *input) |
| Provide support for multiple seed sources. More...
void | RemoveAllSources () |
virtual bool | GetForceSerialExecution () |
| Force the filter to run particle tracer in serial. More...
virtual void | SetForceSerialExecution (bool) |
virtual void | ForceSerialExecutionOn () |
virtual void | ForceSerialExecutionOff () |
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
