vtkLoadStateOptions Class Reference
supports locating files in directory when loading a state file. More...
#include <vtkLoadStateOptions.h>
Inheritance diagram for vtkLoadStateOptions:
Collaboration diagram for vtkLoadStateOptions:
virtual void SetDataDirectory (std::string)
std::string LocateFileInDirectory (const std::string &filepath, int isPath)
 Attempts to locate a file specified by filepath in the directory specified by the DataDirectory member variable. More...
static vtkLoadStateOptionsNew ()
static vtkLoadStateOptionsSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkLoadStateOptions ()
 ~vtkLoadStateOptions () override
std::string DataDirectory
vtkLoadStateOptions supports vtkSMLoadStateOptionsProxy by locating data files in a directory on the data server specified by the user.
Definition at line 18 of file vtkLoadStateOptions.h.
Definition at line 22 of file vtkLoadStateOptions.h.
◆ vtkLoadStateOptions()
vtkLoadStateOptions::vtkLoadStateOptions ( )
◆ ~vtkLoadStateOptions()
vtkLoadStateOptions::~vtkLoadStateOptions ( )
static vtkLoadStateOptions* vtkLoadStateOptions::New ( )
virtual const char* vtkLoadStateOptions::GetClassName ( )
static int vtkLoadStateOptions::IsTypeOf ( const char *  type)
virtual int vtkLoadStateOptions::IsA ( const char *  type)
static vtkLoadStateOptions* vtkLoadStateOptions::SafeDownCast ( vtkObject o)
void vtkLoadStateOptions::PrintSelf ( ostream &  os,
◆ SetDataDirectory()
virtual void vtkLoadStateOptions::SetDataDirectory ( std::string  )
◆ LocateFileInDirectory()
std::string vtkLoadStateOptions::LocateFileInDirectory ( const std::string filepath,
int  isPath
If the file cannot be found, the original filepath is returned. Set the isPath parameter to 0 if you want to locate a file, and set it to 1 if your aim is to replace the directory in the filepath with the DataDirectory member variable if the new directory exists. This can be useful for determining how a file prefix should be changed.
◆ DataDirectory
std::string vtkLoadStateOptions::DataDirectory
Definition at line 42 of file vtkLoadStateOptions.h.
