an image source that can read an image file on one process and ensure that it's available on some other group of processes.
void | UpdateImage () |
| Needs to be called to perform the actual image migration. More...
virtual void | SetFileName (const char *) |
| Get/Set the filename. More...
virtual char * | GetFileName () |
virtual void | SetTrivialProducerKey (const char *) |
| Get/Set the key used to access image from vtkDistributedTrivialProducer. More...
virtual char * | GetTrivialProducerKey () |
| vtkSetEnumMacro (Mode, ModeType) |
| Set the mode in which image data is read. More...
void | SetMode (int mode) |
vtkImageAlgorithm * | NewInstance () const |
vtkImageData * | GetOutput () |
vtkImageData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkImageData * | GetImageDataInput (int port) |
virtual void | AddInputData (vtkDataObject *) |
virtual void | AddInputData (int, vtkDataObject *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkNetworkImageSource () |
| ~vtkNetworkImageSource () override |
int | ReadImageFromFile (const char *filename) |
int | ReadImageFromMemory (const char *trivialProducerKey) |
int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkImageAlgorithm () |
| ~vtkImageAlgorithm () |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual void | CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
virtual void | ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo) |
virtual void | ExecuteData (vtkDataObject *output) |
virtual void | Execute () |
virtual void | AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent) |
virtual vtkImageData * | AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo) |
virtual void | CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
vtkNetworkImageSource is a vtkImageAlgorithm that can read an image file on on the client process and produce the output image data on a client and render-server processes.
Definition at line 22 of file vtkNetworkImageSource.h.
