vtkPANLHaloFinder Class Reference
Given an input a vtkUnstructuredGrid of points with arrays vx, vy, vz, and id, finds clumps of points (halos) using the cosmotools halo finder. More...
#include <vtkPANLHaloFinder.h>
Inheritance diagram for vtkPANLHaloFinder:
Collaboration diagram for vtkPANLHaloFinder:
enum  CenterFindingType { NONE = 0, MOST_BOUND_PARTICLE = 1, MOST_CONNECTED_PARTICLE = 2, HIST_CENTER_FINDING = 3 }
- Public Types inherited from vtkUnstructuredGridAlgorithm
enum  DesiredOutputPrecision
void PrintSelf (ostream &os, vtkIndent indent)
virtual void SetRunSubHaloFinder (bool)
 Turns on/off the subhalo finder part of the algorithm Default: Off. More...
virtual bool GetRunSubHaloFinder ()
virtual void RunSubHaloFinderOn ()
virtual void RunSubHaloFinderOff ()
virtual void SetRL (double)
 Gets/Sets RL, the physical coordinate box size Default: 256.0. More...
virtual double GetRL ()
virtual void SetDistanceConvertFactor (double)
 Gets/Sets the distance conversion factor. More...
virtual double GetDistanceConvertFactor ()
virtual void SetMassConvertFactor (double)
 Gets/Sets the mass conversion factor. More...
virtual double GetMassConvertFactor ()
virtual void SetDeadSize (double)
 Gets/Sets the size of the ghost particle region around each process's particles to exchange when creating ghost particles. More...
virtual double GetDeadSize ()
virtual void SetParticleMass (float)
 Gets/Sets the particle mass. More...
virtual float GetParticleMass ()
virtual void SetBB (double)
 Gets/Sets distance threshold for particles to be considered in the same halo. More...
virtual double GetBB ()
virtual void SetAlphaFactor (double)
 Gets/Sets alpha factor. More...
virtual double GetAlphaFactor ()
virtual void SetBetaFactor (double)
 Gets/Sets beta factor. More...
virtual double GetBetaFactor ()
virtual void SetNP (int)
 Gets/Sets NP Default: 1024. More...
virtual int GetNP ()
virtual void SetNMin (int)
 Gets/Sets the minimum number of close neighbors for a halo candidate to include a particle. More...
virtual int GetNMin ()
virtual void SetPMin (int)
 Gets/Sets the minimum number of particles required for a halo candidate to be considered a halo and output Default: 10000. More...
virtual int GetPMin ()
virtual void SetMinFOFSubhaloSize (long)
 Gets/Sets the minimum halo size to run the subhalo finder on. More...
virtual long GetMinFOFSubhaloSize ()
virtual void SetMinCandidateSize (int)
 Gets/Sets the minimum size of a subhalo candidate Default: 200. More...
virtual int GetMinCandidateSize ()
virtual void SetNumSPHNeighbors (int)
 Gets/Sets NumSPHNeighbors Default: 64. More...
virtual int GetNumSPHNeighbors ()
virtual void SetNumNeighbors (int)
 Gets/Sets the number of neighbors that are examined by the subhalo finder to determine local clumps near the each particle Default: 20. More...
virtual int GetNumNeighbors ()
virtual void SetCenterFindingMode (int)
 Gets/Sets the center finding method used by the halo finder once halos are identified. More...
virtual int GetCenterFindingMode ()
virtual void SetSmoothingLength (double)
 Gets/Sets the smoothing length used by the center finders Default: 0.0. More...
virtual double GetSmoothingLength ()
virtual void SetOmegaDM (double)
 Gets/Sets the OmegaDM parameter of the simulation. More...
virtual double GetOmegaDM ()
virtual void SetOmegaNU (double)
 Gets/Sets the OmegaNU parameter of the simulation. More...
virtual double GetOmegaNU ()
virtual void SetDeut (double)
 Gets/Sets the Deut parameter of the simulation. More...
virtual double GetDeut ()
virtual void SetHubble (double)
 Gets/Sets the Hubble parameter of the simulation. More...
virtual double GetHubble ()
virtual void SetRedShift (double)
 Gets/Sets the current redshift. More...
virtual double GetRedShift ()
- Public Member Functions inherited from vtkUnstructuredGridAlgorithm
vtkUnstructuredGridAlgorithmNewInstance () const
vtkDataObjectGetInput (int port)
vtkDataObjectGetInput ()
vtkUnstructuredGridGetUnstructuredGridInput (int port)
vtkUnstructuredGridGetOutput ()
vtkUnstructuredGridGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPANLHaloFinderNew ()
- Static Public Member Functions inherited from vtkUnstructuredGridAlgorithm
static vtkUnstructuredGridAlgorithmNew ()
static vtkUnstructuredGridAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPANLHaloFinder ()
virtual ~vtkPANLHaloFinder ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
int FillInputPortInformation (int port, vtkInformation *info)
- Protected Member Functions inherited from vtkUnstructuredGridAlgorithm
 vtkUnstructuredGridAlgorithm ()
 ~vtkUnstructuredGridAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
double RL
double DistanceConvertFactor
double MassConvertFactor
double DeadSize
float ParticleMass
double BB
double AlphaFactor
double BetaFactor
int NP
int NMin
int PMin
long MinFOFSubhaloSize
int MinCandidateSize
int NumSPHNeighbors
int NumNeighbors
bool RunSubHaloFinder
int CenterFindingMode
double SmoothingLength
double OmegaNU
double OmegaDM
double Deut
double Hubble
double RedShift
vtkMultiProcessControllerController
vtkInternals * Internal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
The first output is a vtkUnstructuredGrid similar to the input but with the data array fof_halo_tag appended to indicate which halo a point lies in. The value will be -1 for points in no halo. Optionally, subhalo finding can be turned on which will find subhalos of all halos over a certain size. The subhalo id a point is in will be appended as the data array subhalo_tag.
The second output is a summary of halo properties such as mass, center of mass, center (computed via one of several algorithms), and net velocity. This vtkUnstructuredGrid has one point per halo.
The third output is empty unless subhalo finding is turned on. If subhalo finding is on, this output is similar to the second output except with data for each subhalo rather than each halo. It contains one point per subhalo.
Definition at line 33 of file vtkPANLHaloFinder.h.
◆ CenterFindingType
Enumerator
NONE
MOST_BOUND_PARTICLE
HIST_CENTER_FINDING
Definition at line 197 of file vtkPANLHaloFinder.h.
◆ vtkPANLHaloFinder()
vtkPANLHaloFinder::vtkPANLHaloFinder ( )
◆ ~vtkPANLHaloFinder()
virtual vtkPANLHaloFinder::~vtkPANLHaloFinder ( )
protectedvirtual
static vtkPANLHaloFinder* vtkPANLHaloFinder::New ( )
void vtkPANLHaloFinder::PrintSelf ( ostream &  os,
Reimplemented from vtkUnstructuredGridAlgorithm.
◆ SetRunSubHaloFinder()
virtual void vtkPANLHaloFinder::SetRunSubHaloFinder ( bool  )
◆ GetRunSubHaloFinder()
virtual bool vtkPANLHaloFinder::GetRunSubHaloFinder ( )
◆ RunSubHaloFinderOn()
virtual void vtkPANLHaloFinder::RunSubHaloFinderOn ( )
◆ RunSubHaloFinderOff()
virtual void vtkPANLHaloFinder::RunSubHaloFinderOff ( )
◆ SetRL()
virtual void vtkPANLHaloFinder::SetRL ( double  )
◆ GetRL()
virtual double vtkPANLHaloFinder::GetRL ( )
◆ SetDistanceConvertFactor()
virtual void vtkPANLHaloFinder::SetDistanceConvertFactor ( double  )
This is multiplied into all position coordinates before the halo finder is run. Default: 1.0
◆ GetDistanceConvertFactor()
virtual double vtkPANLHaloFinder::GetDistanceConvertFactor ( )
◆ SetMassConvertFactor()
virtual void vtkPANLHaloFinder::SetMassConvertFactor ( double  )
This is multiplied into the particle mass before the halo finder is run. Default: 1.0
◆ GetMassConvertFactor()
virtual double vtkPANLHaloFinder::GetMassConvertFactor ( )
◆ SetDeadSize()
virtual void vtkPANLHaloFinder::SetDeadSize ( double  )
Default: 8.0
◆ GetDeadSize()
virtual double vtkPANLHaloFinder::GetDeadSize ( )
Default: 8.0
◆ SetParticleMass()
virtual void vtkPANLHaloFinder::SetParticleMass ( float  )
For input datasets that do not have mass information the mass of each particle defaults to this value. Default: 1.307087181e+09
◆ GetParticleMass()
virtual float vtkPANLHaloFinder::GetParticleMass ( )
◆ SetBB()
virtual void vtkPANLHaloFinder::SetBB ( double  )
This is measured in grid units on a NP x NP x NP grid. Default: 0.1679999998
◆ GetBB()
virtual double vtkPANLHaloFinder::GetBB ( )
◆ SetAlphaFactor()
virtual void vtkPANLHaloFinder::SetAlphaFactor ( double  )
This controls how aggressively small subhalos are grown. Alpha factor of 1.0 is the least aggressive Default: 1.0
◆ GetAlphaFactor()
virtual double vtkPANLHaloFinder::GetAlphaFactor ( )
◆ SetBetaFactor()
virtual void vtkPANLHaloFinder::SetBetaFactor ( double  )
This controls how saddle points between subhalos are treated. Larger values allow identification of smaller scale structures such as tails. Default: 0.0
◆ GetBetaFactor()
virtual double vtkPANLHaloFinder::GetBetaFactor ( )
◆ SetNP()
virtual void vtkPANLHaloFinder::SetNP ( int  )
◆ GetNP()
virtual int vtkPANLHaloFinder::GetNP ( )
◆ SetNMin()
virtual void vtkPANLHaloFinder::SetNMin ( int  )
Default: 1
◆ GetNMin()
virtual int vtkPANLHaloFinder::GetNMin ( )
Default: 1
◆ SetPMin()
virtual void vtkPANLHaloFinder::SetPMin ( int  )
◆ GetPMin()
virtual int vtkPANLHaloFinder::GetPMin ( )
◆ SetMinFOFSubhaloSize()
virtual void vtkPANLHaloFinder::SetMinFOFSubhaloSize ( long  )
Default: 10000
◆ GetMinFOFSubhaloSize()
virtual long vtkPANLHaloFinder::GetMinFOFSubhaloSize ( )
Default: 10000
◆ SetMinCandidateSize()
virtual void vtkPANLHaloFinder::SetMinCandidateSize ( int  )
◆ GetMinCandidateSize()
virtual int vtkPANLHaloFinder::GetMinCandidateSize ( )
◆ SetNumSPHNeighbors()
virtual void vtkPANLHaloFinder::SetNumSPHNeighbors ( int  )
◆ GetNumSPHNeighbors()
virtual int vtkPANLHaloFinder::GetNumSPHNeighbors ( )
◆ SetNumNeighbors()
virtual void vtkPANLHaloFinder::SetNumNeighbors ( int  )
◆ GetNumNeighbors()
virtual int vtkPANLHaloFinder::GetNumNeighbors ( )
◆ SetCenterFindingMode()
virtual void vtkPANLHaloFinder::SetCenterFindingMode ( int  )
Default: NONE
◆ GetCenterFindingMode()
virtual int vtkPANLHaloFinder::GetCenterFindingMode ( )
Default: NONE
◆ SetSmoothingLength()
virtual void vtkPANLHaloFinder::SetSmoothingLength ( double  )
◆ GetSmoothingLength()
virtual double vtkPANLHaloFinder::GetSmoothingLength ( )
◆ SetOmegaDM()
virtual void vtkPANLHaloFinder::SetOmegaDM ( double  )
Used by the center finding algorithms. Default: 0.26627
◆ GetOmegaDM()
virtual double vtkPANLHaloFinder::GetOmegaDM ( )
◆ SetOmegaNU()
virtual void vtkPANLHaloFinder::SetOmegaNU ( double  )
Used by the center finding algorithms. Default: 0.0
◆ GetOmegaNU()
virtual double vtkPANLHaloFinder::GetOmegaNU ( )
◆ SetDeut()
virtual void vtkPANLHaloFinder::SetDeut ( double  )
Used by the center finding algorithms. Default: 0.02258
◆ GetDeut()
virtual double vtkPANLHaloFinder::GetDeut ( )
◆ SetHubble()
virtual void vtkPANLHaloFinder::SetHubble ( double  )
Used by the center finding algorithms. Default: 0.673
◆ GetHubble()
virtual double vtkPANLHaloFinder::GetHubble ( )
◆ SetRedShift()
virtual void vtkPANLHaloFinder::SetRedShift ( double  )
◆ GetRedShift()
virtual double vtkPANLHaloFinder::GetRedShift ( )
◆ RequestInformation()
virtual int vtkPANLHaloFinder::RequestInformation ( vtkInformation ,
vtkInformationVector **  ,
protectedvirtual
◆ RequestData()
virtual int vtkPANLHaloFinder::RequestData ( vtkInformation ,
protectedvirtual
◆ FillInputPortInformation()
int vtkPANLHaloFinder::FillInputPortInformation ( int  port,
vtkInformation info
protectedvirtual
◆ RL
double vtkPANLHaloFinder::RL
Definition at line 281 of file vtkPANLHaloFinder.h.
◆ DistanceConvertFactor
double vtkPANLHaloFinder::DistanceConvertFactor
Definition at line 282 of file vtkPANLHaloFinder.h.
◆ MassConvertFactor
double vtkPANLHaloFinder::MassConvertFactor
Definition at line 283 of file vtkPANLHaloFinder.h.
◆ DeadSize
double vtkPANLHaloFinder::DeadSize
Definition at line 284 of file vtkPANLHaloFinder.h.
◆ ParticleMass
float vtkPANLHaloFinder::ParticleMass
Definition at line 285 of file vtkPANLHaloFinder.h.
◆ BB
double vtkPANLHaloFinder::BB
Definition at line 286 of file vtkPANLHaloFinder.h.
◆ AlphaFactor
double vtkPANLHaloFinder::AlphaFactor
Definition at line 287 of file vtkPANLHaloFinder.h.
◆ BetaFactor
double vtkPANLHaloFinder::BetaFactor
Definition at line 288 of file vtkPANLHaloFinder.h.
◆ NP
int vtkPANLHaloFinder::NP
Definition at line 289 of file vtkPANLHaloFinder.h.
◆ NMin
int vtkPANLHaloFinder::NMin
Definition at line 290 of file vtkPANLHaloFinder.h.
◆ PMin
int vtkPANLHaloFinder::PMin
Definition at line 291 of file vtkPANLHaloFinder.h.
◆ MinFOFSubhaloSize
long vtkPANLHaloFinder::MinFOFSubhaloSize
Definition at line 292 of file vtkPANLHaloFinder.h.
◆ MinCandidateSize
int vtkPANLHaloFinder::MinCandidateSize
Definition at line 293 of file vtkPANLHaloFinder.h.
◆ NumSPHNeighbors
int vtkPANLHaloFinder::NumSPHNeighbors
Definition at line 294 of file vtkPANLHaloFinder.h.
◆ NumNeighbors
int vtkPANLHaloFinder::NumNeighbors
Definition at line 295 of file vtkPANLHaloFinder.h.
◆ RunSubHaloFinder
bool vtkPANLHaloFinder::RunSubHaloFinder
Definition at line 297 of file vtkPANLHaloFinder.h.
◆ CenterFindingMode
int vtkPANLHaloFinder::CenterFindingMode
Definition at line 300 of file vtkPANLHaloFinder.h.
◆ SmoothingLength
double vtkPANLHaloFinder::SmoothingLength
Definition at line 301 of file vtkPANLHaloFinder.h.
◆ OmegaNU
double vtkPANLHaloFinder::OmegaNU
Definition at line 302 of file vtkPANLHaloFinder.h.
◆ OmegaDM
double vtkPANLHaloFinder::OmegaDM
Definition at line 303 of file vtkPANLHaloFinder.h.
◆ Deut
double vtkPANLHaloFinder::Deut
Definition at line 304 of file vtkPANLHaloFinder.h.
◆ Hubble
double vtkPANLHaloFinder::Hubble
Definition at line 305 of file vtkPANLHaloFinder.h.
◆ RedShift
double vtkPANLHaloFinder::RedShift
Definition at line 306 of file vtkPANLHaloFinder.h.
◆ Controller
vtkMultiProcessController* vtkPANLHaloFinder::Controller
Definition at line 308 of file vtkPANLHaloFinder.h.
◆ Internal
vtkInternals* vtkPANLHaloFinder::Internal
Definition at line 310 of file vtkPANLHaloFinder.h.
