vtkPCosmoReader Class Reference
Read a binary cosmology data file. More...
#include <vtkPCosmoReader.h>
Inheritance diagram for vtkPCosmoReader:
Collaboration diagram for vtkPCosmoReader:
typedef vtkUnstructuredGridAlgorithm Superclass
- Public Types inherited from vtkUnstructuredGridAlgorithm
enum  DesiredOutputPrecision
void PrintSelf (ostream &os, vtkIndent indent)
 Specify the name of the cosmology particle binary file to read. More...
virtual char * GetFileName ()
virtual void SetRL (float)
 Specify the physical box dimensions size (rL) (default 100.0) More...
virtual float GetRL ()
virtual void SetOverlap (float)
 Specify the ghost cell spacing in Mpc (in rL units) (edge boundary of processor box) (default 5) More...
virtual float GetOverlap ()
virtual void SetReadMode (int)
 Set the read mode (0 = one-to-one, 1 = default, round-robin) More...
virtual int GetReadMode ()
virtual void SetCosmoFormat (int)
 Set whether to byte-swap or not the data. More...
virtual int GetCosmoFormat ()
virtual vtkMultiProcessControllerGetController ()
 Set the communicator object for interprocess communication. More...
virtual void SetController (vtkMultiProcessController *)
- Public Member Functions inherited from vtkUnstructuredGridAlgorithm
vtkUnstructuredGridAlgorithmNewInstance () const
vtkDataObjectGetInput (int port)
vtkDataObjectGetInput ()
vtkUnstructuredGridGetUnstructuredGridInput (int port)
vtkUnstructuredGridGetOutput ()
vtkUnstructuredGridGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPCosmoReaderNew ()
static vtkPCosmoReaderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkUnstructuredGridAlgorithm
static vtkUnstructuredGridAlgorithmNew ()
static vtkUnstructuredGridAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPCosmoReader ()
 ~vtkPCosmoReader ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
- Protected Member Functions inherited from vtkUnstructuredGridAlgorithm
 vtkUnstructuredGridAlgorithm ()
 ~vtkUnstructuredGridAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkMultiProcessControllerController
char * FileName
float RL
float Overlap
int ReadMode
int CosmoFormat
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPCosmoReader creates a vtkUnstructuredGrid from a binary cosmology file.
A cosmo file is a record format file with no header. One record per particle.
Each record is 32 bytes, with fields (in order) for: x_position (float), x_velocity (float), y_position (float), y_velocity (float), z-position (float), z_velocity (float) mass (float) identification tag (int64_t)
Total particle data can be split into per processor files, with each file name ending in the processor number.
Definition at line 38 of file vtkPCosmoReader.h.
Definition at line 42 of file vtkPCosmoReader.h.
◆ vtkPCosmoReader()
vtkPCosmoReader::vtkPCosmoReader ( )
◆ ~vtkPCosmoReader()
vtkPCosmoReader::~vtkPCosmoReader ( )
static vtkPCosmoReader* vtkPCosmoReader::New ( )
virtual const char* vtkPCosmoReader::GetClassName ( )
static int vtkPCosmoReader::IsTypeOf ( const char *  type)
virtual int vtkPCosmoReader::IsA ( const char *  type)
Reimplemented from vtkUnstructuredGridAlgorithm.
static vtkPCosmoReader* vtkPCosmoReader::SafeDownCast ( vtkObject o)
void vtkPCosmoReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkPCosmoReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkPCosmoReader::GetFileName ( )
◆ SetRL()
virtual void vtkPCosmoReader::SetRL ( float  )
◆ GetRL()
virtual float vtkPCosmoReader::GetRL ( )
◆ SetOverlap()
virtual void vtkPCosmoReader::SetOverlap ( float  )
◆ GetOverlap()
virtual float vtkPCosmoReader::GetOverlap ( )
◆ SetReadMode()
virtual void vtkPCosmoReader::SetReadMode ( int  )
◆ GetReadMode()
virtual int vtkPCosmoReader::GetReadMode ( )
◆ SetCosmoFormat()
virtual void vtkPCosmoReader::SetCosmoFormat ( int  )
Applicable only to Cosmo format. By default, no byte-swapping is enabled. vtkSetMacro(ByteSwap,int); vtkGetMacro(ByteSwap,int); Set the filetype to Gadget or Cosmo read mode (0 = Gadget, 1 = default, Cosmo)
◆ GetCosmoFormat()
virtual int vtkPCosmoReader::GetCosmoFormat ( )
◆ GetController()
virtual vtkMultiProcessController* vtkPCosmoReader::GetController ( )
◆ SetController()
virtual void vtkPCosmoReader::SetController ( vtkMultiProcessController )
◆ RequestInformation()
virtual int vtkPCosmoReader::RequestInformation ( vtkInformation ,
vtkInformationVector **  ,
protectedvirtual
◆ RequestData()
virtual int vtkPCosmoReader::RequestData ( vtkInformation ,
protectedvirtual
◆ Controller
vtkMultiProcessController* vtkPCosmoReader::Controller
Definition at line 111 of file vtkPCosmoReader.h.
◆ FileName
char* vtkPCosmoReader::FileName
Definition at line 113 of file vtkPCosmoReader.h.
◆ RL
float vtkPCosmoReader::RL
Definition at line 114 of file vtkPCosmoReader.h.
◆ Overlap
float vtkPCosmoReader::Overlap
Definition at line 115 of file vtkPCosmoReader.h.
◆ ReadMode
int vtkPCosmoReader::ReadMode
Definition at line 116 of file vtkPCosmoReader.h.
◆ CosmoFormat
int vtkPCosmoReader::CosmoFormat
Definition at line 118 of file vtkPCosmoReader.h.
