int | GetNumberOfPointArrays () |
| Returns the number of arrays in the file, i.e., the number of columns. More...
const char * | GetPointArrayName (int i) |
| Returns the name of the ith array. More...
int | GetPointArrayStatus (const char *name) |
| Returns the status of the array corresponding to the given name. More...
void | SetPointArrayStatus (const char *name, int status) |
| Sets the status of the array corresponding to the given name. More...
vtkIdType | GetRequestedHaloId (vtkIdType i) |
| Gets the ith requested halo id. More...
vtkIdType | GetNumberOfRequestedHaloIds () |
| Gets the number of requested halo ids. More...
void | SetNumberOfRequestedHaloIds (vtkIdType numIds) |
| Sets the number of requested halo ids. More...
void | AddRequestedHaloId (vtkIdType haloId) |
| Adds the given halo id to the list of halo ids to request. More...
void | ClearRequestedHaloIds () |
| Clears the list of requested halo ids. More...
void | SetRequestedHaloId (vtkIdType i, vtkIdType haloId) |
| Sets the ith requested halo id to the given haloId. More...
virtual void | SetXAxisVariableName (const char *) |
| Set/Get the variable name to be used as the x-axis for plotting particles. More...
virtual char * | GetXAxisVariableName () |
virtual void | SetYAxisVariableName (const char *) |
| Set/Get the variable name to be used as the y-axis for plotting particles. More...
virtual char * | GetYAxisVariableName () |
virtual void | SetZAxisVariableName (const char *) |
| Set/Get the variable name to be used as the z-axis for plotting particles. More...
virtual char * | GetZAxisVariableName () |
virtual void | SetFileName (const char *) |
| Specify the name of the cosmology particle binary file to read. More...
virtual char * | GetFileName () |
virtual void | SetGenericIOType (int) |
| Set/Get the underlying IO method the reader will employ, i.e., MPI or POSIX. More...
virtual int | GetGenericIOType () |
virtual void | SetBlockAssignment (int) |
| Set/Get the underlying block-assignment strategy to use, i.e., ROUND_ROBIN, or RCB. More...
virtual int | GetBlockAssignment () |
virtual vtkStringArray * | GetArrayList () |
| Returns the list of arrays used to select the variables to be used for the x,y and z axis. More...
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
virtual vtkMultiProcessController * | GetController () |
| Set/Get a multiprocess-controller for reading in parallel. More...
virtual void | SetController (vtkMultiProcessController *) |
virtual void | SetHaloIdVariableName (const char *) |
| Gets/Sets the variable name for the halo id of the particle. More...
virtual char * | GetHaloIdVariableName () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPGenericIOMultiBlockReader () |
| ~vtkPGenericIOMultiBlockReader () |
gio::GenericIOReader * | GetInternalReader () |
bool | ReaderParametersChanged () |
void | LoadMetaData () |
void | LoadRawVariableDataForBlock (const std::string &varName, int blockId) |
void | LoadRawDataForBlock (int blockId) |
void | GetPointFromRawData (int xType, void *xBuffer, int yType, void *yBuffer, int zType, void *zBuffer, vtkIdType id, double point[3]) |
void | LoadCoordinatesForBlock (vtkUnstructuredGrid *grid, std::set< vtkIdType > &pointsInSelectedHalos, int blockId) |
void | LoadDataArraysForBlock (vtkUnstructuredGrid *grid, const std::set< vtkIdType > &pointsInSelectedHalos, int blockId) |
vtkUnstructuredGrid * | LoadBlock (int blockId) |
virtual int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkMultiBlockDataSetAlgorithm () |
| ~vtkMultiBlockDataSetAlgorithm () |
virtual vtkExecutive * | CreateDefaultExecutive () |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
