This reader handles multiple GenericIO files that are different resolutions of the same dataset.
void | PrintSelf (ostream &os, vtkIndent indent) |
virtual bool | CanReadFile (const char *fileName) |
void | SetXAxisVariableName (const char *arg) |
virtual char * | GetXAxisVariableName () |
void | SetYAxisVariableName (const char *arg) |
virtual char * | GetYAxisVariableName () |
void | SetZAxisVariableName (const char *arg) |
virtual char * | GetZAxisVariableName () |
vtkStringArray * | GetArrayList () |
bool | InsertLevel (const char *fileName, int level) |
| This function inserts the given file as a resolution level on this reader. More...
int | GetNumberOfLevels () const |
| Gets the number of resolution levels known by this reader. More...
const char * | GetFileNameForLevel (int level) const |
| Gets the filename for the given resolution level. More...
void | RemoveAllLevels () |
| Clears all resolution levels. More...
int | GetNumberOfPointArrays () |
| Returns the number of arrays in the file. More...
const char * | GetPointArrayName (int i) |
| Returns the name of the ith array. More...
int | GetPointArrayStatus (const char *name) |
| Returns the status of the array corresponding to the given name. More...
void | SetPointArrayStatus (const char *name, int status) |
| Sets the status of the array corresponding to the given name. More...
void | SetFileName (const char *fname) |
| Sets/Gets the filename to be read by this reader. More...
virtual char * | GetFileName () |
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPMultiResolutionGenericIOReader () |
| ~vtkPMultiResolutionGenericIOReader () |
int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkMultiBlockDataSetAlgorithm () |
| ~vtkMultiBlockDataSetAlgorithm () |
virtual vtkExecutive * | CreateDefaultExecutive () |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
This reader aggregates these and allows streaming different resolutions on different parts of the dataset. It has the concept of a resolution level with 0 being the lowest resolution and the resolution increases as the level number increases.
Definition at line 24 of file vtkPMultiResolutionGenericIOReader.h.
